oil leak
Old Mar 12, 2003 | 12:45 AM
cndctrdj's Avatar
oil leak
i got an oil leak out of the little sensor on the drivers side of the oil pan. is that a common thing and is thier an easy fix. i havn't taken it out yet and was just wondering if i had to replace the whole sensor or just a gasket? any idea of what im talking about?
Old Mar 12, 2003 | 12:55 AM
maserati82's Avatar
I had a leak in the exact same place.
I went to the dealership and told them what was leaking, and it seemed as if I could just replace the o-ring washer seal thingy and be done with it, but of course I had to break the whole sensor pulling the thing out. That was a $50 mistake.
The problem I had though was the stupid cat that was right in front of it, so I had to pull it out at an angle. I don't know about the 95's, but I don't think they have a cat there, so it shouldn't be a problem.
But yeah, just go to the dealership and see if they have a seal for the sensor (I think it is the low oil sensor), and hopefully you won't have to buy a whole new unit
Old Mar 12, 2003 | 02:47 AM
Est96Z28's Avatar
Exactly the same problem here and I had to buy a new sensor.
I'm still wondering is this low oil sensor operational on our cars, because I drove for a while wires not connected and didn't get check gauges or any other warning light ?
Old Mar 13, 2003 | 05:48 PM
cndctrdj's Avatar
thanks alot ill be carefull with it when i take it out, next time i change the oil. is the gasket washer thing expensive
Old Mar 13, 2003 | 06:58 PM
ZPaul2Fresh8's Avatar
Cost me $26 for a oil pressure sending unit... you'll need a special socket to remove and install it. Sounds expensive at first
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
BigWil
Mar 29, 2015 12:24 PM
artic94
Jan 17, 2015 11:19 AM
