Anyone run cogs?
Old Mar 11, 2003 | 09:18 PM
Willie's Avatar
Anyone run cogs?
Just installed a custom made set on my D1SC equipped third gen. It whines slightly louder than my blower!! Is this normal? I hope so cause it really sounds sweet!!
Old Mar 11, 2003 | 09:22 PM
IROCrdracer's Avatar
Mine make no sound at all.
Old Mar 11, 2003 | 09:28 PM
Willie's Avatar
Could it have something to do with the pitch of the teeth? My belt is a Gates belt, 50mm wide with 8mm teeth.
Willie
Old Mar 11, 2003 | 09:39 PM
Willie-running the 35 MM here-not sure what the noise is you are hearing-the cogs and belt can be run with much less tension than a 6 or 8 rib set up. ??? Good luck.
Old Mar 11, 2003 | 09:45 PM
Willie's Avatar
I appreciate the response anyways. All I know is that with my previouse 12-rib setup, all I could hear was the blower. I still hear the blower, but you really have to listen carefully because I've now got this other whining. I'm assuming it's coming from the cogs/belt.
And yes, much less tension!! And most importantly, no more belt dust!!!! Thanks again.
Willie
Old Mar 12, 2003 | 06:46 AM
Guido's Avatar
Thumbs up
I had no idea you were upgrading Willie. You'll have to keep us updated on how much the car improves with them.
Good luck!
Old Mar 12, 2003 | 06:57 AM
Willie's Avatar
Guido,
I've kept this mod to myself. This post is the first time I've mentioned it anywhere. Once I have track results, I'll post results on your board. Stay tuned....
Willie
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
1LEThumper
Jul 14, 2003 12:45 PM
