Nitrous problem. Won't rev over 5100rpm???
Old Mar 9, 2003 | 11:08 PM
JamesN1830's Avatar
Whenever I hit the juice (nitrous works 125 shot), the car will not rev over 5100rpms at all. It does this on any size shot; 50-150. I've changed plugs from ngk to autolite with no help.
Any ideas?
Old Mar 10, 2003 | 02:45 AM
racr4jc's Avatar
Will it rev over 5100 without the nitrous? Have you checked the rest of your ignition (opti, wires, connections, etc?). Also, what about bottle pressure? If you don't have enough nitrous going to the solenoids, then your mixture will go dead rich because of all the extra fuel being injected. Just some thoughts...
Old Mar 10, 2003 | 11:14 AM
JamesN1830's Avatar
The car off nitrous revs fine over 5100 rpms. The ignition seems fine. The o2's also seem to be ok.
Old Mar 10, 2003 | 05:22 PM
Lonnie Pavtis's Avatar
Do you have an aftermarket ignition? If so, what type & what is your plug gap?
This will tell a lot.
Old Mar 10, 2003 | 06:00 PM
JamesN1830's Avatar
I've got msd 6a and autolites 104 gapped at .35. I've tried it with and without the msd. same results. I don't get it.
Could egr or header leak do this? One of the two are leaking.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
bowtieboy95
Jul 1, 2015 06:49 AM
kxrawx
May 25, 2015 08:29 PM
bandit383lt4
Dec 21, 2014 09:12 PM
