Fuel gauge doesn't work?
Old Mar 9, 2003 | 01:50 PM
remaxracer45's Avatar
When I energize my ingnition the gas guage goes to 1/4 then drops to zero? when the car sits with the ignition off it sits on a 1/8? I have ran 15 tanks of gas thru it hoping maybe the float was stuck? HELP
Thanks Shawn
Old Mar 9, 2003 | 03:16 PM
To help figure out what your fuel gauge problem is, locate the connector on the rear of the floor pan under the car that has the purple, gray and black wires going to the fuel tank. Remove the connector and with a meter, read resistance between the black and purple wires going to the tank.
approximate:
88 ohms = full
60 ohms = 3/4
43 ohms = 1/2
26 ohms = 1/4
1 ohm = empty
The readings should correspond to your gauge. If the reading(s) seem accurate to what you have in the tank, the sender is ok.
Garcia5
Jul 7, 2022 06:51 PM
ANDYZ28
Dec 29, 2014 09:13 PM
nophix
Nov 30, 2014 10:26 PM
Evilfrog
Aug 7, 2002 11:36 PM
Snake Slayer
Jul 26, 2002 06:14 AM
