Any fix for left turn rearend squeal?
Old Mar 9, 2003 | 11:24 AM
Hal Fisher's Avatar
Has anyone come up with a way to fix that horrible rearend squeal you get when you take hard left hand turns?
Hal
Old Mar 9, 2003 | 12:04 PM
C Man's Avatar
Funny that someone else has the same problem. I've had the car for 4 years no problems... until this winter.
Will be checking out the brakes when I switch to summer tires.
Anyone have an idea of what to could be?
Old Mar 9, 2003 | 12:42 PM
cndctrdj's Avatar
i always thought that noise was your posi, the clutch discs in thier made noise when they had to turn. i could be completely wrong but thats what i thoguth the noise was
Old Mar 9, 2003 | 02:09 PM
Josh'95Z28conv's Avatar
I had the same noise. I changed the fluid, and all was good. I guess when the fluid gets old the posi starts acting up or something. Try changing your fluid and see if that works. Remember to use the limited slip additive too.
Old Mar 9, 2003 | 02:17 PM
CODY BEHNKE's Avatar
Most 93+ cars use a Auburn Diff, it has no cluches only cones and they will make more of a chatter than a whine.
Old Mar 9, 2003 | 02:21 PM
bunker's Avatar
Acctually what happens is I think the C-clamps start to give, basicly if you jack the car up, you will notice that the wheel will move towards you & away from you a bit, now when you move it towards you, you'll notice that a section of the caliper itself (not the pad) it touching the disk brake & makes groves in it if its bad enough, what I did to compensate on my 93 was I removed the brake caliper bolts (the two sleeve/travel bolts) that hold the caliper on & I put washers in between them & that takes away the slack/play
Old Mar 9, 2003 | 02:27 PM
xxsaint69x's Avatar
you sir are WRONG.
Only the Torsen posi does not have clutches, and does not need GM Additive to be added when u change fluids. Auburn Rear has clutches (cone clutches), and DOES need GM Additive when u change the fluid.
If your rear is makin noise when u turn, i would suggest u add some fluid...that should fix it 99%.
MArcin
Old Mar 9, 2003 | 02:59 PM
1994TransAm's Avatar
bunker is the only right person here...reguarding the squeal!!!
the clips wear out and alow the axle to slide a bit..the axle rubs the calipers and makes the noise... i fixed mine by replacing the rear end
Old Mar 9, 2003 | 03:11 PM
Hal Fisher's Avatar
Thanks Bunker. I know its a caliper problem and not a diff issue.
I broke one of the Energy Suspension front swaybar mounts "just driving". They asked me to return the broken part when they sent a new one. Guess they weren't made tough enough for people to throw their car sideways through a turn
Hal
Old Mar 9, 2003 | 04:18 PM
Hal Fisher's Avatar
It looks like it might be scrapping the front outer portion of the rotor on both sides. Does this need to be done on both rear calipers?
Also, you are talking about the outer most caliper bolts (with rubber boots), not the ones that mount it to the axle, right?
And last, how many washers does it take, one on each bolt? These go by the head of the bolt, not somewhere inbetween, right?
Hal
Old Mar 9, 2003 | 04:39 PM
Ummmm, I didn't say a Auburn wouldn't need Additive.
Old Mar 9, 2003 | 05:06 PM
any f-body posi rear end needs the GM slip additive!!
ddr698
Jan 9, 2015 10:05 AM
CaRParts102
Dec 6, 2014 08:45 AM
formula79
26
Aug 5, 2002 12:21 PM
MislMan
Jul 19, 2002 11:41 AM
