fuel pressure regs for high boost applications
Old Mar 9, 2003 | 12:07 AM
bowtiepwr's Avatar
Question fuel pressure regs for high boost applications
>So which FPR are you using with high boost applications ?
and what is the difference between the Aeromotive #13101 and #13109 FPR's ?
Old Mar 9, 2003 | 02:50 PM
Monty's Avatar
Depends on what you consider "high boost", but I'm running 20-25 psi of boost and I'm using an Aeromotive Pro-Series Boost Reference EFI Regulator, P/N 13110, which will flow enough fuel to support up to around 2000hp.
The 13109 uses -06 inlet fittings, the 13101 uses -10 inlet fittings. Both are ideal for use with the A1000 fuel pump and are adjustable from 30-70psi and feature a 1:1 fuel pressure ratio when boost referenced.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Nostang 96z
Sep 10, 2002 08:54 PM
