brakes after hotcam?
Old Mar 8, 2003 | 12:58 PM
1994TransAm's Avatar
Angry brakes after hotcam?
hi there,
took the car for a spin today to help solve my idle problems and i fixed a vaccum leak. but my brakes are crappy!!!
they dont stop the car like they used to... before the cam
i know i dont have any leaks, so i how can i improve my braking (vaccum) with a cam, is there something i can put in the brake lines leading to the master cyclinder to impove the vac?
Old Mar 8, 2003 | 01:28 PM
ZPaul2Fresh8's Avatar
Man! I had the same problem, and I am STILL having this same problem! I bled my brakes etc... Can someone please find an answer to this problem.
I bought a new master cylinder that I hope will fix this problem!!! Anyone?
Old Mar 8, 2003 | 02:21 PM
CJ Black LS1 Z28 M6's Avatar
Thumbs down
Amazing! I have the same problem. The only difference is I didn't drive my car in 2 months and I took it to my boy's house to repair a few things I almost crashed. It felt like the braking system on a tank
Old Mar 8, 2003 | 02:24 PM
vodoo-chile's Avatar
It will be a little expected that your brakes down hold as much as before due to less vacuum created by the cam. Have you checked to see how much vacuum your engine is getting at idle and other various rpm's? If I recall correctly, anything lower than about 10-12 psi of vacuum is not good for power brakes. They (who THEY is, I don't know lol) do make a Vacuum canister to assist in storing vacuum to assist with power brakes and bigger cams. With a Hotcam, I wouldn't expect it to be needed though. I would continue to look for other vacuum leaks.
Kyle
Old Mar 8, 2003 | 02:27 PM
Dr.Mudge's Avatar
I went with a larger cam and had no problems with my brakes. If your VE is poor at low RPM (poor MAP), then you will have less vacuum than you should, in which case you need to tune the car.
Old Mar 8, 2003 | 02:28 PM
i went from head to toe... no leaks...
i dont know my vaccum but i know its not enough!!!
is there an inline vaccum booster you can buy ?
Old Mar 8, 2003 | 03:06 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
u want to see no vac?
i'll let u drive my car-
brakes are 90% WOT when i'm stopped
Old Mar 8, 2003 | 05:09 PM
Josh-'04 GTO's Avatar
No way hotcam should leave you with no brakes. Time to buy a vacuum guage and find out what type of vacuum your motor is producing.
One problem you may be having is that the idle in the computer is not high enough for the cam. My brakes seemed a little funky with the cam and stock idle setting. It was very noticeable until I used LT1 edit to bump up the idle.
Old Mar 8, 2003 | 05:14 PM
Well, I had my chip burnt by Brian at PCM for LEss so the tuning shouldn't be an issue. I as well don't have any vacuum leaks. I will check out the vacuum psi when I take it back to work, what's the range I should be at?
Old Mar 8, 2003 | 05:36 PM
Depending on the condition of the engine, mods, etc, you should see anywhere from 16-20 psi at idle.
Kyle
Old Mar 8, 2003 | 06:36 PM
Hey Trey, how much did those Dnyomax Longtubes run ya? Hows the clearance?
Old Mar 8, 2003 | 06:42 PM
treyZ28's Avatar
I bought them used with like 300 miles on them
they costed me around $500 shipped but i got a killer deal.
i lost zero ground clearance
Old Mar 8, 2003 | 10:13 PM
94 CAMRO Z28's Avatar
Thats wierd, I was not able to tell a difference with my brakes after the hotcam kit. Maybe this is because I have a 6spd?? Even before tunning I didn't really notice any difference.
Aaron
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
MDZ28
11
Sep 24, 2015 09:15 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
maverickmk
Sep 1, 2015 09:17 PM
