How to maintain pressure w/ 15 lb bottle
Old Mar 8, 2003 | 06:51 AM
MPM IV's Avatar
I recently put a NX kit on my car, and I went with a 15 lb bottle so I wouldn't have to refill so often. I got the NX bottle heater, but I still have trouble getting to 900psi and the bottle is almost full. Does anyone make a blanket for a 15lb bottle? I appriciate any suggestions.
Old Mar 8, 2003 | 01:41 PM
CustomN2O's Avatar
Yes, NX makes a blanket for the 10 and 15lb bottles. Make sure you have large wires running to the bottle heater. They take alot of power to get working. It should be hot to the touch when its working right. It usually takes about 15 minutes to heat my 15lber from around 600-1000psi. If you arent driving your car, the battery probably wont be able to supply enough power to really get it hot. I hook up a 75 amp battery charger to get the heater going.
Old Mar 9, 2003 | 08:13 AM
MPM IV's Avatar
Thanks! I'd never seen one listed anywhere. The heater does get hot, but the bottle has a lot of air pass over it. Hopefully this will solve my problem.
Old Mar 9, 2003 | 08:24 PM
CustomN2O's Avatar
Here is a picture of one. Let me know if you have any other questions. They are really thick, and made nice. Better then some other brands on the market.
http://www.zimmermanmotorsports.com/...iteria=&rec=10
Old Mar 9, 2003 | 08:33 PM
stik6shift98's Avatar
why is nx blanket 100 and nos blanket like 35?????
Old Mar 9, 2003 | 10:29 PM
CustomN2O's Avatar
If you had each one in your hands, you wouldnt have to ask. The NX blanket is very nice, thick quality. And they work much better.
Old Mar 10, 2003 | 06:45 PM
MPM IV's Avatar
Ok, one other question and it might be stupid. It's not thick enough to be a problem fitting in the bottle brackets is it? This is the first car I've ever sprayed, so it's all pretty new to me.
Old Mar 10, 2003 | 07:27 PM
no its preety loose..its not like a virgin thats for sure
KYWes
Jun 14, 2022 06:52 AM
350350
14
Aug 11, 2015 12:03 PM
GT what?
Jul 14, 2015 10:17 PM
Noct
Jul 14, 2015 01:18 AM
