OBD I and OBD II
Old Mar 7, 2003 | 11:36 PM
5thCamaro's Avatar
OBD I and OBD II
on my 95 could I remove the OBD II connector and wire in a OBD I
Old Mar 8, 2003 | 01:55 AM
turbo_Z's Avatar
what exactly are you trying to accomplish?
Old Mar 8, 2003 | 06:45 AM
No reason you couldn't replace the 16-pin connector with a 12-pin. There are only about 4 wires involved. Or, you could just get an adapter cable from AKM Electronics.
Old Mar 8, 2003 | 09:20 AM
5thCamaro's Avatar
I am trying to use the scanner I have now due to the fact I cannot find a obdI scanner with a II plug
Old Mar 8, 2003 | 09:31 AM
Make some little jumpers for your scanner plug to connect like this and you are all set.
Old Mar 8, 2003 | 01:54 PM
5thCamaro's Avatar
Shoebox
My scanner is a sunpro cp9001 and it looks nothing like the one in the picture. It has three terminal and in a different configuration. any ideas?
Old Mar 8, 2003 | 03:10 PM
Shoebox
It is the connector that you are trying to adapt. It does not matter what scanner it is. The connector to the DLC is the same.
Your scanner must use the two terminals to read the pcm.
Novo
Jun 14, 2016 02:58 AM
4586
Sep 6, 2015 03:10 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
Aug 7, 2015 08:52 AM
