3.4L intake?
Old Mar 7, 2003 | 08:27 PM
oil pan 4's Avatar
Lightbulb 3.4L intake?
I back home, I have found a 3.4 intake from TB to intake mainifold with fuel componets. No computer.
I wanted to know if the stock (50mm) 3.4 TB would bolt on a 2.8/3.1 type manifold?
Are there were any more parts of that 3.4 intake I could use on an engine powered by a 2.8 computer?
Old Mar 7, 2003 | 10:39 PM
Wolfie's Avatar
it will bolt up,but the pull is defernt,and the 2.8/3.1 tb is the same size as it (52mm)
Old Mar 8, 2003 | 12:17 AM
MustangEater82's Avatar
personally the 3.4L upper intake is junk!
A few fiero guys have dynoed abotu 20 hp gain from this modified middl 2.8/3.1 intake pelnum.
Old Mar 8, 2003 | 10:49 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
it isnt just you , the 3.4L upper intake is junk... i have decided the engineers that made it were just trying to make it fit under the hood and dash.... it really is a peice of crap, look at it , the air enters and makes a turn right after the TB , then it makes another turn to enter th plenum area, then down into the runners... it is a poor design. i was thinking about trying to make it so it took 2 TB's one for each plenum, but i decided to go the easy route, im getting an LT1 TB and im gonna strap that biatch on her instead
Naanz
V6 Tech
Feb 14, 2016 11:11 AM
mike062772
Jun 17, 2015 05:40 PM
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
