WTF...tranny mount?
Old Mar 7, 2003 | 03:10 PM
Dave19yz28's Avatar
WTF...tranny mount?
i am in the process of putting in a new tranny mount...i took the old one out and now ive got the new one on...im lookin at it under the car...lining up the bar that goes across and bolts to the bottom of the car...and it looks like there is going to be a hung gap...am i supposed to just tourqe the 4 bolts down as far as i can??...HELP!!
Old Mar 7, 2003 | 03:13 PM
Provide more description of what is on where, how you have it supported and what you are doing next. I don't quite understand what you are saying.
Old Mar 7, 2003 | 03:16 PM
Dave19yz28's Avatar
sorry....the new tranny mount...p/n 22201140 looks like it is too "thick". I sized up the cross brace that the bolt that is stickeing out of the bottom of the mount stickes through, which the nut goes onto, and it looks like the brace will be too far away from the underside of the car, where the 4 bolts that hold it to the underside of the car go through
Old Mar 7, 2003 | 03:39 PM
That mount is a little taller. It is not a problem, though. I would put some support under the trans or under your crossmember (however you decide) and move it all up until the crossmember is up next to the underside of the car. If you pull it up with the bolts, you risk stripping the threads.
Old Mar 7, 2003 | 03:48 PM
kevkop94TA's Avatar
Thumbs up
Couldn't have said it any better myself.
Old Mar 7, 2003 | 07:07 PM
Dave19yz28's Avatar
thanks shoebox...i jacked up the trans and got everythig to fit in fine...god were my fingers numb. I took the car out for a drive...woohoo...no rattles....for the first 5 minutes. now it rattles at idle, and throughout the RPM range...it used to only rattle when starting out, low in 1st gear. I got back under....tried to tighten the bolts as much as i possibly good...and it still rattles. Anyone have any ideas...maybe its not the tranny mount??
Old Mar 7, 2003 | 08:22 PM
Dave19yz28's Avatar
I checked all the exhaust piping before i determined it was a tranny mount the 1st time...i dont think its them...but it never hurts to double check. As for the rattling, it sounds like it is coming from behind the drivers seat, and sometimes i can feel it when my foot is of the clutch through the floor. Anyone else have any ideas?
Old Mar 7, 2003 | 08:40 PM
RENE95Z's Avatar
Check the U-joints also, before long, you're gonna have a checklist of things to check.
Old Mar 7, 2003 | 08:57 PM
Z95m6's Avatar
You are one of the first M6 guys i have seen to break a tranny mount.
Old Mar 7, 2003 | 09:02 PM
Dave19yz28's Avatar
i know....it was this winter...i ran over a big pice of icy snow that fell off the wheel well of a truck on a two lane higway...couldnt swerve outa the way
Old Mar 7, 2003 | 09:04 PM
Dave19yz28's Avatar
Originally posted by 2CNTRY
So it was the tranny mount the first time and now it isn't? Check the piping again. Another possibility is the pipe clamps are loose. But you probably checked that as well. Can't think of what else but something related to the exhaust. If it rattles during idle then I don't see why you shouldn't be able to look under during idle and isolate the location.
that is an excellent idea...ill definately do this next time i am home...why didnt i think of that??
G-BODYT56
Jan 14, 2022 11:14 PM
alliance12364
Sep 23, 2015 12:40 PM
alliance12364
Sep 23, 2015 06:09 AM
War Engine
Sep 18, 2015 07:28 PM
Daluchman1974
Sep 11, 2015 06:12 AM
