Hooker long tubes Left #1 primary
Old Mar 6, 2003 | 08:33 PM
Chuck2's Avatar
I bought a set of hookers super comp long tubes ceramic coated and when i opened them o noticed thta the number one primary on the drivers' side isnt connected to the flange that bolts the the head and will come completely off the rest of the header. I assume that this is made this way but after i install them, do i need to weld this? Im sure some of you have run into this. Thanks
Old Mar 6, 2003 | 08:34 PM
Rodrigues's Avatar
Heh... That is normal, if you welded that piece the headers would never come out of the car. It is necissary to be able to install them.
Old Mar 6, 2003 | 08:36 PM
Chuck2's Avatar
how do i make it so it doesnt leak though. Can i just throw a clamp on there or what?
Old Mar 6, 2003 | 08:47 PM
97WRAITH's Avatar
If it is a tight fit it shouldn't leak.It seems some are tight and some loose.If it is loose you can buy a T-bolt clamp.Summit Racing sell them I think for around $7.Good luck.
Old Mar 6, 2003 | 09:01 PM
SnkEatr's Avatar
dont weld it man that part is intentionally like that so you can get the header around your steering arm. shouldn't leak once you heat cycle them a couple of times.
Old Mar 6, 2003 | 09:19 PM
Javier97Z28's Avatar
Moderator
On the past 3 cars I have installed Hooker's on we have used hitemp RTV on the slip fit and have never had a leak out of any of the cars. No need to weld or clamp, it's usually a really tight fit, and after the heat cycles there's no way it leaks
Old Mar 6, 2003 | 09:21 PM
Chuck2's Avatar
THe tubes on mine are tight but not sure if they're tight enough to seal. I guess Ill install them and if they sela then great but if not ill have to jew rig something.
Old Mar 6, 2003 | 09:37 PM
Moderator
mine would slide in and out with ease, after the RTV and starting it up there are no signs of leak..
don't worry so much
Jan 5, 2015 07:14 PM
ModdedNerd
Jan 1, 2015 10:56 AM
RedLineRev
Jan 23, 2003 03:51 PM
KASR_Z28
Aug 6, 2002 03:34 PM
Wicked
Jul 29, 2002 04:17 PM
