Help with LCA'S!!
Old Mar 5, 2003 | 07:49 PM
Grn96Z's Avatar
Help with LCA'S!!
I heard that these are pretty easy to put in. I want to do them tomorrow before I bring my car to get the sfc welded in. Anyone wanna tell me exactly how to do it, or know of an install page, I looked but couldnt find a link that worked. Thank alot I wanna get these in before going to the track on saturday!!!
Old Mar 5, 2003 | 07:57 PM
RamAir95TA's Avatar
Pretty easy. Just make sure you do one side at a time, so you won't have a hell of a time trying to realign the rear.
Roll the rear on ramps (or jacks under the axle tubes). You need the weight of the car on the rear suspension. Two 18mm bolt/nut combos, and they should pop right out. Install new ones, and be sure to use plenty of grease on the fittings. Poly bushings will squeak., alot.
Best of luck.
Old Mar 5, 2003 | 08:04 PM
Grn96Z's Avatar
thanks alot, but maybe im retarded but how would the weight of the car be on the rear suspension with the rear wheels on ramps, wouldnt the front then have all the wieght?
Old Mar 5, 2003 | 08:11 PM
funina91ss's Avatar
you have to jack it up on the rearend and leave the jack under it also put some jack stands under the rear rails incase the jack gives out but pretty easy to do...
96SilverRam
Nov 20, 2016 11:19 AM
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
Boss002
Jul 24, 2015 10:47 AM
