guys with bmr weld in rlc brackets inside please....
Old Mar 5, 2003 | 05:13 PM
MattysTA's Avatar
I just got some rlc brackets from someone but they didnt have the bolts, anyone know what size they are? and also what kind of welder did you use to weld them up with? i only have a 88 amp 120 volt stick welder with 3/16th rods is that enough? thanks for the help.........
Old Mar 5, 2003 | 06:56 PM
MattysTA's Avatar
Noboy knows? i know you guys have them.......
Old Mar 5, 2003 | 07:51 PM
95_RipperZ's Avatar
I was wondering the same thing. I bought mine used off of a board member and they did not come with bolts like the BMR site shows.
Do I need them?
Old Mar 5, 2003 | 10:24 PM
MattysTA's Avatar
I just emailed their tech guys and here is the info we need:
Yes, you can get sufficient penetration with anything 75 amps or higher. You will need two 12mm bolts approximately 4" long, two 12mm nuts, and eight 1/2" large diameter washers. You will also need two spacers to keep the stock rear end bracket from crushing when the bolts are tightened. The spacers need to be the same width as the control arm. If you don't have these available, we sell the complete hardware kit for $14.95. Just give us a call at 813-655-3983 to place an order.
Thanks,
BMR Tech
rjc1629
Jan 27, 2015 10:46 AM
HectorM52
Jan 16, 2015 10:21 AM
squarehead
Nov 21, 2014 08:02 PM
Red97LT1
Aug 7, 2002 05:45 PM
