Anyone got an idea of why Im breaking torque arm......
Old Mar 4, 2003 | 07:57 PM
ChrisJ325's Avatar
..... on shifts?? I could understand breaking a stock one on a launch, but on a 3-4 shift the first time and a 2-3 shift this time We thought it was because my driveshaft was too long so I had it shortened after the first one broke, and now it breaks another one?? Its ripping the end that bolts to the rear end center section off (the bolts stay in the housing, the top of the torque arm is the part that breaks). I wasnt on nitrous when this happened either time... Both just quick jumps on motor, and I let off the gas when I shifted, but I did shift really hard... One of my friends said its because my clutch grabs so hard might be what is causing it, but hell I dont know What do you guys think? Is it just time for an aftermarket torque arm or what?
Old Mar 4, 2003 | 08:04 PM
kick Z tail out's Avatar
Talking
Yuo suXor at teh shifting.
Old Mar 4, 2003 | 08:06 PM
Larnach's Avatar
I'd be happy to trade my A4 tranny with $800 for your M6 tranny.
Old Mar 4, 2003 | 08:10 PM
ChrisJ325's Avatar
lol... nah, im happy with my M6... thanks though
Old Mar 4, 2003 | 08:11 PM
Larnach's Avatar
Not if ya keep breaking torque arms
Old Mar 4, 2003 | 08:12 PM
ChrisJ325's Avatar
lmao!! nah, im pretty sure thats not the case
Old Mar 4, 2003 | 08:39 PM
Birdie2000's Avatar
Have you checked your rearend for anything acting up in there?
The reason I ask is because I broke my aftermarket torque arm in the same manner you did. I then took it into a shop because I was having some clunking coming from the rear. It turns out that my carrier was ovaled out and the gears would engage, then the slack would tighten, and then the wheels would engage. Because everything was so loose, when the wheels finally did grab it was much more of a shock than normal and exerted much more force than usual. It is believed that this in turn broke my torque arm. Just something to think about.
Old Mar 4, 2003 | 09:17 PM
ChrisJ325's Avatar
Hmmm.. Something to think about.. Thing is this happened on two seperate 12 bolts.. Ill check that out though. Thanks for the tip
Old Mar 5, 2003 | 11:11 AM
ChrisJ325's Avatar
anyone else?
t
t
t
Old Mar 5, 2003 | 11:26 AM
Appears you are running a stock TA on a 12-bolt.... which one? Moser (alters TA bolt setup) or Strange (uses "stock" bolt setup)?
Have you checked pinion angle?
Old Mar 5, 2003 | 12:57 PM
ChrisJ325's Avatar
Yeah.. stock TA on Moser 12 bolt. I havent checked my pinion angle.. Thought never crossed my mind that its possible that could have something to do with it. What should I look for when I check it?
Old Mar 5, 2003 | 01:38 PM
Z28SORR's Avatar
The answer to this is simple, your rear end is "twisting" or wrapping to much. The question then becomes why?
So, have you replaced all the rubber in the system? LCA's, panhard rod, trans mount, torque arm bushing, engine mounts....etc. And/or do you have a pinion snubber like this...http://store.summitracing.com/partde...?part=4276...?
The ultimate answer to this is of course to get an aftermarket torque arm.
Old Mar 5, 2003 | 01:53 PM
Gripenfelter's Avatar
What is your pinion angle?
Most people set it to -4.
Old Mar 5, 2003 | 03:47 PM
I generally follow Steve Spohn's recommendation... -2deg for stock and bolt-ons, -4deg for major power adders. Steve also recommends that you use -4deg ONLY on the track, and reset to -2deg for the street. I run -3deg all the time, but my car is seldom street driven.
Since you have the Moser 12-bolt, you might want to see if the mounting points shift the TA off to the left. That could possibly cause the TA bushing to bind, and limit the ability of the TA to change length to provide for the relative rotation of the axle around the LCA and the TA. I've seen aftermarket TA's bind like that and rip the rear mount apart. Hard to understand how the stock rubber, or even a poly bushing would bind though.
Old Mar 5, 2003 | 09:54 PM
ChrisJ325's Avatar
Thanks for the tips guys I ordered a BMR Extreme Duty and BMR Weld-in SFCs tonight. hopefully this will solve the problem.. Would my car having true duals be limiting the movement of the TA enough to hurt it? My only suspension mods are Eibach Sportline springs, and !front sway bar. My rear sway bar end link broke (bolt broke) so I wasnt running a rear sway bar either, but thats just temporary. Any of that stuff might lead to it? Someone told me that I may not have been tightening the bolts enough.. They were very tight though, to the point they wouldnt turn anymore with a breaker bar on the ratchet.
