EGR block-off
Old Mar 4, 2003 | 05:54 PM
super83Z's Avatar
EGR block-off
Where could I get an EGR block off other than Ebay I don't feel comfortable getting one from there.
Old Mar 4, 2003 | 06:17 PM
wantafastz28's Avatar
Make one.
Old Mar 4, 2003 | 06:43 PM
nB5sP's Avatar
what would blocking off the EGR do? i've heard about it a while ago but i forgot specifically what it does. could anyone explain?
does it effect emissions?
Old Mar 4, 2003 | 07:19 PM
Yes it affects emissions. For performance, removing it does nothing. It is so far in the back and out of the way, I don't know why people even bother with it.
People commonly remove them if they have headers with no provision for the EGR feed tube that goes to the RH exhaust.
Old Mar 4, 2003 | 07:39 PM
Russtebo's Avatar
Exhaust Gas Recirculation. It does add a significant amount of heat to the back of the manifold and has been blamed (Though not proven) to be the cause of the Intake manifold oil leak. Does the air travel too fast through the intake to be effected by the increased temperature though? Anyone done a before/after dyno test with just !EGR?
You can usually re-use the old egr parts as block-off plates, just plug any openings....be creative.
Old Mar 4, 2003 | 07:51 PM
ba96ta's Avatar
there would be no gain at WOT because the egr is blocked off when you get on it or above a certain rpm. It recycles the exhaust to lower cylinder temps. below 2500 degrees because the exhaust produces alot more emissions above that temp.
Old Mar 4, 2003 | 09:49 PM
cals400ex's Avatar
did anyone notice a increase in temperature after doing this mod?
Old Mar 5, 2003 | 05:25 AM
super83Z's Avatar
Yeah I need it because I am putting Jet-Hot's headers in.
Old Mar 5, 2003 | 06:38 AM
Smoke T/A's Avatar
http://www.mycamaroz28.homestead.com/
Old Mar 5, 2003 | 10:05 AM
Janny's Avatar
If you have dime in your pocket you have an EGR blockoff. Slop it up with RTV put the gasket over it and install. It's invisible too!
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
Jlo
Jul 29, 2015 03:52 PM
