which electric water pump needs modified?
Old Mar 4, 2003 | 12:57 PM
CamaroZBoy's Avatar
there are two electric water pumps for 93-97 LT-1 f-body's, the meziere one and one other one that i know of. Which one needs to be modified to fit correcty and which does not. Is one better than the other. There is a price difference so im just checking before i buy. Thanks
Cory
Old Mar 4, 2003 | 01:32 PM
GREGG 97Z's Avatar
They Meziere and the CSI both require some modication to install. With the Mez you need to cut some of the fan shroud to make it fit but the pump fits in the stock waterpump housing without any modification. With the CSI you just have to grind the wp housing a bit to get it in, not much really, took about five minutes to do. I went with the CSI since it was much cheaper and just as good from what I hear.
Old Mar 4, 2003 | 02:16 PM
Red95Formula's Avatar
I also went with CSI because of price! The notches in the housing are easy to make and it takes maybe 5 mins. Also, i think it looks better than having to cut the fan shroud.
Chad
Old Mar 4, 2003 | 03:21 PM
lt1camaroman93's Avatar
I also use the csi and it only took a couple min to grind what needed to be grinded
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Stay Puft
Apr 20, 2015 06:24 PM
Queens94z28
Dec 20, 2014 09:11 PM
Zone
Jul 29, 2002 07:43 PM
