396 stroker??
Old Mar 1, 2003 | 11:44 PM
turb0racing's Avatar
396 stroker??
I just read the post about the 396 stroker pistons and i would like to know if they produce 5.850 rods or do you have to get them custom made? I know if your using a ofset ground 383 crank it will make the journals smaller what kind of bearing do they use? Why dont i hear alot about 396 builds?
Old Mar 2, 2003 | 09:13 AM
Jason Short's Avatar
Alot of people here have 396 motors. 5.85" rods can be used without a problem, just make sure that your piston (compression height) is correct for using that rod.
I dont know of one person using an offset ground 3.75" (383) for a 396 motor here, everyone just goes with a 3.875" stroke. That along with a 4.030" bore yeilds 396ci.
Old Mar 2, 2003 | 01:16 PM
kmook's Avatar
Advanced Tech Moderator
You should get a lot of responses on this in LT1 Tech, moving...
Thanks.
Old Mar 2, 2003 | 06:45 PM
Can i put a 3.875 crank in my old 69' 010 block? Can i use H beam or must i use i beam rods for clearing the block? Who makes a 3.875 crank?
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95craz28
11
Sep 12, 2015 07:47 AM
Cbr02
Aug 23, 2015 10:55 PM
TGGodfrey
Aug 18, 2015 06:08 PM
