any program out so i can change the VIN in the PCM?
Old Mar 1, 2003 | 03:22 PM
AHARTZ28's Avatar
Question any program out so i can change the VIN in the PCM?
does anyone have a program or know where to get one to change the PCM VIN? i got my PCM done originally by ed wright and the VIN was incorrect and i didnt notice b/c it was one digit off and i reprogrammed my PCM with the TECH2 to redo everything from scratch well the VIN is off now instead of 2G1 like its supposed to be it 2G2 and now my Lt1 edit wont work let me know if you know of any thing to fix it
thanks Ryan
Old Mar 1, 2003 | 06:00 PM
Another Red Z's Avatar
http://www.fbody.com/members/jz97ss1500/ try the vin edit
Old Mar 1, 2003 | 07:40 PM
AHARTZ28's Avatar
VIN edit will not work i have it, it is the PCM VIN that is now incorrect b/c the edit says another VIN than the PCM b/c 1 digit was miss keyed or something by ed wright originally
Old Mar 2, 2003 | 01:56 PM
n2oTransAmLT1's Avatar
Im not too sure of any other options....but it sounds like you better hope the carputing guys will feel bad and help you out with this one. Maybe they can reset whatever needs reset so LT1 edit can recognize anther VIN #...good luck. If they reset it...let me know what lines you used in case this happens to me one day. Later
Old Mar 2, 2003 | 04:11 PM
Dr.Mudge's Avatar
VIN edit / VIN chng only changes the VIN in a file, not on the PCM. You cannot change the PCM VIN yourself, too many criminals have done this in the past so it is not readily accessible. Talk to a dealership, or if your desperate there are other methods. Are you sure Ed even gave you the same PCM back? If it was only off one digit then I assume he did.
DirtyDaveW
Dec 1, 2016 05:37 PM
thenewkid
Apr 12, 2015 07:42 PM
Bearmans
Dec 3, 2014 05:28 AM
Jul 4, 2005 05:00 PM
Caps94ZODG
Aug 5, 2002 06:31 PM
