Looking for ideas of ultimate tranny..
Old Mar 1, 2003 | 10:30 AM
SWINGRRR's Avatar
After 125,xxx miles I am going to go though the tranny. Any ideas on a good setup? Would rather buy a rebuild kit, and have it put in locally.
Old Mar 2, 2003 | 04:45 AM
Pro Built Automatics's Avatar
Go to https://www.pro-built.net/index.cfm?...t&productid=48 check out what comes in this kit, it should be more than enough in most cases. I would add the GM HD sunshell to this, as for the reverse input drum and low/reverse planet, only if they are questionable and need to be replaced. Do not cut corners, as you will pay in the end.
Old Mar 2, 2003 | 09:05 PM
SWINGRRR's Avatar
Minor note: I need it for 4L6O and what is the difference between HD and Street/Strip?
Old Mar 3, 2003 | 03:18 AM
The Street/Strip 700R4 will allow you to shift the gears or leave it in drive or overdrive for full automatic upshifts. It has a cleaner 3-2 downshift & a better 2-3 upshift mainly because of the Trans-Go Performance Shift kit & Hi-Rev springs. The S/S uses Kolene steels in the 3-4 clutch pack. It can handle up to about 550 horsepower (HD 475-500 horsepower max) safely as long as you use a 10" or smaller diameter torque converter.
TGGodfrey
Aug 18, 2015 06:08 PM
Rittmeister
Aug 12, 2015 03:50 AM
Rittmeister
Aug 7, 2015 01:13 AM
Devinfoote87
Parts Wanted
Aug 6, 2015 05:05 PM
asilomar244
Jul 12, 2015 05:53 AM
