which cam to install with stock heads
Old Mar 1, 2003 | 06:05 AM
Prorac1's Avatar
I have to do an opti unit pretty soon, so i figure while im at it i may as well do a cam and switch to a vented opti. What are your experiences? What cam will work best with the mods i have (in sig). And what gains should i expect 1/4 mile wise. Thanks in advance. Prorac1
Old Mar 1, 2003 | 06:09 AM
nateh's Avatar
Hot cam kit.
Old Mar 1, 2003 | 06:16 AM
texasTA's Avatar
Yeah I 2nd the Hotcam. Very good streetable cam for stock heads.
Old Mar 1, 2003 | 11:53 AM
Z95m6's Avatar
i would go comp cams XE 224/230
Old Mar 1, 2003 | 12:02 PM
97Z-M6's Avatar
this cam will make more power than the hot cam. so just get it ground on a 114 and it will be very streetable
Old Mar 1, 2003 | 01:37 PM
25th-transam's Avatar
I also just installed a comp 224/230 with a 112 lsa. Most people will agree this is probably the largest cam for non-ported heads, although it does work well w/ ported heads also. I can't give you any gains or 1/4 mile times, but it does pull alot better on the top end. I'd recommend this over the hotcam. If you're wondering about pt #s for valvetrain components here's a site,
http://www.compcams.com/catalog/086_087.html
(its listed as the Extreme RPM "503")
Kurt
Old Mar 1, 2003 | 02:07 PM
I am going to be putting in that exact cam pretty soon.
Old Mar 1, 2003 | 03:41 PM
nateh's Avatar
I'm putting in a 224/230 (113 lsa) cam as well, but I also have ported heads. I still think you can't beat the value of the hot cam for stock, unported heads.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
Killer94z
Jan 13, 2015 12:06 PM
birdblack
Dec 30, 2014 06:59 PM
GigaMp3z
Feb 20, 2003 02:57 PM
