How to drain oli from A/C compressor
Old Feb 28, 2003 | 02:16 PM
John Winkeler's Avatar
How to drain oil from A/C compressor
Guys,
Dumb question, where is the drain located on the A/C compressor? I need to remove and measure the amount of oil in the old compressor and can't figure out where the drain is (looking at the new compressor).
Thanks in advance,
John
Old Feb 28, 2003 | 06:22 PM
nateh's Avatar
No drain that I know of. The oil will be removed when you evacuate the system before recharging. There is a sticker on the compressor that tells how much and what kind (synthetic compressor oil) of oil to put in the system when recharging. I usually add the oil first, after evacuation.
Old Feb 28, 2003 | 07:38 PM
So, are you adding pressurized oil? Or do you add liquid oil directly to the compressor (I guess through the pressure side lines)? If pressurized, how are you determining that you are adding the correct amount?
The info in the helms manual and compressor says to drain and measure the oil in the compressor, then add new oil dependent upon the amount drained.
Thanks again,
John
Old Feb 28, 2003 | 07:46 PM
whitehooptie's Avatar
I will say this. I just get one of those 8 oz. cans and let that get in there, then put in a few more cans of 134. You might have to let some more back out though. Might put too much in. I have done it that way more times than I can count on both hands, the a/c system has survived to motor blow ups, and abuse and it still blows cold without any funny sounds.
Old Feb 28, 2003 | 07:48 PM
nateh's Avatar
You use pressurized oil. It comes in a can with a mixture of refrigerant and oil. Put that in first and follow with the correct amount of straight refrigerant.
Old Feb 28, 2003 | 08:24 PM
Thanks for all the replies.
John
2QUIK6
Sep 17, 2016 02:31 PM
magman
Apr 15, 2016 03:08 AM
War Engine
Sep 18, 2015 07:28 PM
WPHIG2
Aug 27, 2015 06:37 AM
AtlasXVIII
Aug 24, 2015 11:41 PM
