GEARS: 2.73 to 3.42 tech help needed
Old Feb 28, 2003 | 01:58 PM
94CamaroZ28's Avatar
1994 Camaro Z28, A4, 2.73 stock rear, ABS, no TCS, 108k miles, no real mods just CAI and !MAF screen
What exactly is involved in going to 3.42 gears in this car from the stock 2.73s?
What does it cost?
Where should I buy the parts? Which parts can be reused?
What happens if I do not reprogram computer to accommodate the gear change?
Old Feb 28, 2003 | 02:11 PM
Kain's Avatar
Re: GEARS: 2.73 to 3.42 tech help needed
www.thunderracing.com
Most all of them. I had 2.73's, then I got Strange Gears 3.73's for a 2 series carrier. So I paid for the gears and thats it, and I had a shop install them. 2.73-3.08 gears have a 2 series carrier, 3.23 and up have a 3 series carrier. So if you got regular 3 series carrier gears, you'd have to get a new carrier, which is a lot more money.
Here's what you need: 23-875342-X Strange Pro-Street Gears, 3.42 Gear Ratio, 2 series carrier, GM 7.5" 10 bolt rear end
$225.00
Your speedo and odometer will be waaaaay off. Causing you to rack up milage way faster, and your speedo will say your going 100, instead of 60. Get programming from Bryan from www.pcmforless.com He did mine, it was cheap, and he does damn good work.
Old Feb 28, 2003 | 02:14 PM
94 NO TOP Z's Avatar
Same as above + if you don't reprogram the computer the tranny will not shift right because it shifts by MPH which will be off with the new gears.
Old Feb 28, 2003 | 02:49 PM
You might want to spring for an "install kit" that replaces your carrier and pinion bearings. It is a good idea to do that while you are in there. Count on around another $100 for that.
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
TitoPR221
Jan 29, 2015 08:00 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
