1/4 times on a 94 z????
Old Feb 28, 2003 | 10:16 AM
cridom's Avatar
its m6 and it has 47,000 miles
Old Feb 28, 2003 | 10:24 AM
stik6shift93's Avatar
If it's stock and in good condition, you're a good driver and aren't at a high altitude. You should be able to pull a 14 flat maybe a 13.8-13.9 if you can hammer the gears good.
Old Feb 28, 2003 | 10:42 AM
HungryT/A's Avatar
I went 14.02 on a track with NO prep or whatsoever, elevating, and about 800-900 meters above sea level.
Oh, yeah, and with a full tank of gas
60'ft was 2.4 , 1/8m 9.4sec
See mods in sig.
Old Feb 28, 2003 | 11:17 AM
Thats a good time, over here at our elevation you probably would have clocked off a 13.7.
Old Feb 28, 2003 | 12:55 PM
HungryT/A's Avatar
Yeah, the first time I ran a 14.15 and was very dissapointed. I thought: Damn, those guys over there are runnin' like mid-to-low 13's with the same bolt-ons...
But then came an LS1 A4 Vette, and ran a 14.1 Than I was told that the "track" goes uphill.
BTW, what is exactly track preparation in the US? Special tarmac, some kind of rubber or what...?
Old Feb 28, 2003 | 01:03 PM
chesee48's Avatar
Here in IL on a crappy track..in WI
Stock, I ran a 14.3 with a 2.4 60ft..
Pretty crappy
Old Feb 28, 2003 | 01:08 PM
COMNBYU's Avatar
if its in good shape (which it sounds like it should be w/ only 47k) and you can drive descent, 13s shouldnt be a problem.
my '96 A4 2.73 car, which technically only has 10 more hp than you, ran a 13.62 @ 102 when stock.
jon
Old Feb 28, 2003 | 01:39 PM
chesee48's Avatar
jon
13.6 stock? thats HELLA good...
where are u located???
Old Feb 28, 2003 | 01:44 PM
97Z-M6's Avatar
jon
what was your 60 ft time an d1/8 mile, if you remember.
Old Feb 28, 2003 | 01:50 PM
COMNBYU's Avatar
just outside of Richmond VA. i normally run at Richmond Dragway which is at sea level. i ran that # this past season before i made any modifications whatsoever.
one thing to note- i ran that time ONE time. never did back it up. i made 3 more passes the same day after the 13.6 and went two 13.77s both at 101 and then a 13.80 @ 100. those runs were all in a row one right after the other so the car never had a chance to cool. the day was almost perfect as well. 60fts on all runs was 2.0X.
normally, the car runs 13.7s-.9s depending on the weather. in the dead of summer the heat/humidity can really take a toll.
jon
Old Feb 28, 2003 | 01:53 PM
COMNBYU's Avatar
1/8 on the 13.62 pass was 8.83 @ 81.34. 60ft was 2.01.
jon
Old Feb 28, 2003 | 02:28 PM
scottslt1z28's Avatar
i would say about 14 to 13.9.....................wow...13.6 stock (i do realize you said you did this only once)......i hope mine runs that, i have yet to test to see....the only different in mine is i have a 3:23 gear ratio...........i have heard people saying 14.1- 14.3 is normal for our cars......i didnt like that ........i hope mine produces like yours does.........assuming i drive it as well and dont spin ........................anyways.....back to the post.........i think about 13.9 to 14..................much higher if you havnt really gotten the hang of driving it yet.......................thats my $.02
Scott
Old Mar 1, 2003 | 12:51 AM
cridom's Avatar
im kinda new to m6 can anyone give me tips?
or advice how to shift and at what rpms?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
