Bad water pump & now the car has a miss please help!!
Old Feb 28, 2003 | 06:30 AM
94DROPTOPZ28's Avatar
OK here's my question this is on my 97 LT1 this car is almost brand new since I have replaced almost everything under the hood except the water pump and the opti-spark. The car has new plugs & wires and new coil and new ignition. The other day when I put the car up on the lift the water pump is leaking and the opti-spark looks a little wet and the car is starting to stumble & sputter, and it is throwing an SES light and when I test it the code is random or multiple cylinder misfire. I have checked all of the plugs and wires and everything is good. From what I have read here on the board that a "bad" opti-spark will NOT throw an SES light (is the OBD2 just that much more sensitive)?? I have to change the water pump so the opti-spark is no big deal, I just want to make sure its bad before I replace it, does anybody have ANY other suggestions on how to find out if the opti-spark is "bad"??
Thank you in advance for you're help.
Old Feb 28, 2003 | 06:57 AM
mojo's Avatar
It is possible your Opti is going bad with the water pump leaking on it-mine did throw a code before it went out,but mine was OBD1
Old Feb 28, 2003 | 08:01 AM
1QUIKTA's Avatar
If you are replacing the water pump you might as well change out the opti anyway. Better safe than sorry.
Old Feb 28, 2003 | 02:51 PM
TTT
Old Feb 28, 2003 | 04:46 PM
Blue89Bird's Avatar
your opti went out
bout 300 and an afternoon, sorry to hear about it.
Old Feb 28, 2003 | 06:02 PM
Hey it's just another great engineering design by GM!
Goes with the territory I guess?
Thanks for the input.
Old Mar 1, 2003 | 02:44 AM
Thanks everyone!
My plug wire on cylinder #1 was not on the spark plug all of the way & causing a misfire, for some reason it came loose & that was my problem.
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
thenewkid
Nov 27, 2014 09:41 AM
USAirman93
Nov 24, 2014 03:37 PM
cristian1311
Nov 23, 2014 02:22 PM
