Where do you think a 150 shot will put me
Old Feb 27, 2003 | 12:13 AM
Drew778/94Z's Avatar
Smile Where do you think a 150 shot will put me
We have a fastest street car shoot-out March 29.
I'm thinking about putting the 150 jets in what do you guys think?
I'll be running on Nitto DR's.
Also I haven't made a full run on the spray with the converter yet.
Old Feb 27, 2003 | 02:10 AM
KamaroL98's Avatar
mid 11s, mabey better with that converter...
Old Feb 27, 2003 | 04:55 PM
stik6shift93's Avatar
if traction holds I'd say mid to low 11s.
Good luck.
Old Feb 27, 2003 | 05:56 PM
91ReDZ's Avatar
11.40s to 11.60s if you can hook up. (might be better hard to say with different track conditions everwhere) sprayn ls1
Old Feb 27, 2003 | 11:16 PM
Thanks,
Do you guys think the stock fuel system can handle if I use VP 103 race gas.
Or should I just try a 125 shot?
Thanks again!!!
Old Feb 28, 2003 | 10:37 AM
With the stock fuel system anything over a 100 is asking for trouble. Though I know several people that have gotten away with a 150 shot on the stock system, I'd just make sure you had a fpss and/or a fp gauge to monitor pressure.
Old Feb 28, 2003 | 12:51 PM
COMNBYU's Avatar
with traction, AT LEAST low 11s. if its a good day (air/temp) its possible you could even see a 10.9.
as far as the fuel system, you should be fine. ive seen more than one LS1 car go 150 on stock fuel system. like was said, try it before you go to track and make sure the PSI is there. if so, all is fine.
jon
Old Feb 28, 2003 | 10:59 PM
Smile
Thanks, I'll see if I can have someone scan my car.
Old Apr 8, 2003 | 02:00 AM
Here's the results:
2.164 8.447 93.41 12.598 119.96
1.990 7.884 94.76 12.001 120.29
2.148 8.247 93.95 12.390 119.80
2.133 7.995 94.47 12.119 119.98
1.753 7.414 95.99 11.510 120.60
2.188 8.452 91.96 12.659 117.12
2.142 8.239 91.65 12.513 115.73
1.889 7.608 95.52 11.718 120.29
If the weather didn't suck, I might have done a little better.
Old Apr 8, 2003 | 08:20 AM
stik6shift98's Avatar
Originally posted by Drew778/94Z
Here's the results:
those arent half bad...wait till it gets nicer
Old Apr 8, 2003 | 04:39 PM
craigffb's Avatar
We live in Hawaii, it's always nice.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
Ws6Envy
Mar 3, 2015 04:31 PM
Noer
Feb 28, 2015 11:29 AM
Jan 13, 2015 09:52 PM
