Driveshaft WHAP!
Old Feb 26, 2003 | 11:06 PM
johnboy211's Avatar
Question Driveshaft WHAP!
Some of you may have read in my other posts about my little accident....If not here it is.
I recently adapted a 78' camaro 8.5, 10 bolt posi 3:73 gear rear end to replace an open diff. under my 67 camaro. it involved Moving the spring perches and shortening my drive shaft. everything seemed to go very smooth.
I took the camaro out for the first time and noticed a small vibration. I run 13 in wide tires on the back that probably need balancing so I didn't think much of it and continued my test drive. I decided, after babying the car for an hour, to pick up the speed.....MISTAKE.
At about 70mph w/o warning (no vibration whatsoever) a bomb went off underneath the car. I quickly shut down the car and PROCEEDED to CLEAN OUT MY DRAWERS and scream a few choice words.
upon inspection I found that I spit out a U_joint.....make a 3ft battering ram out of my driveshaft which shredded the transmission hump under the rear seat...beat to crap my expensive flowmaster exhaust system and finally crack my tranny bellhousing in two!!!!
I am now looking for replacement parts on a limited budget. So here is my question(probably not my last).
Does someone know what a driveshaft under a 78' camaro would measure from one center of the u-joint to the other?
After shortening my old shaft, it measures 49' joint to joint. I really don't have the money to spend to have another one shortened and balanced!
Old Feb 27, 2003 | 01:31 AM
Bliggida's Avatar
I've got a stock '79 from the TH-350 to the differential. I'll measure tomorrow for you.
Old Feb 27, 2003 | 06:41 PM
Bliggida's Avatar
From centerline to centerline on the U-joints I got 48-1/2 inches.
Old Feb 27, 2003 | 10:10 PM
67Man's Avatar
Thats crazy.... same th ing happend to me today, sept i just got to get another u joint. Thank god i got strong cast iron bellhousing.
Old Feb 28, 2003 | 06:13 PM
johnboy211's Avatar
Thanks guys,
I think 481/2 will work just fine....I know where I can get a 2nd gen driveshaft....Save a lot of money!
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
realistyc
Jul 28, 2015 07:32 PM
