engine degreaser
Old Feb 26, 2003 | 06:00 PM
jd13's Avatar
engine degreaser
I just got my car back a little ago and the engine compartment is quite dirty, so I'm gonna clean it. Most degreasers are pretty much the same, so that's not the question. This may be kinda stupid, but I've never cleaned an LS1 before.
Is there anything I need to cover up while cleaning the engine and the surrounding accessories? I will be taking the car to a local car wash where I can use a pressure sprayer to rinse the the stuff off the engine. What else do I need to look out for?
Old Feb 26, 2003 | 07:40 PM
96SFLZ's Avatar
Use as little water as possible. I'd also recommend not using a pressure washer, use just a regular hose if you can or if not, then just fill your bucket up with water and rinse it off with that.
Make sure you stay away from the PCM...and try to stay away from the different sensors (MAF, KS, TPS, etc).
willismoons
Feb 14, 2015 08:42 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
centric
Aug 15, 2002 09:04 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
