whats your redline?
Old Feb 26, 2003 | 09:53 AM
camaroSSlover's Avatar
Talking whats your redline?
I think the 97 lt4 has a 6,300 rpm redline. Can you spin a motor that high with a hot cam kit?
whats needed to spin a lt1 that high?
whats your redline?
Old Feb 26, 2003 | 09:56 AM
Gripenfelter's Avatar
I can rev to 6900 no problem but I shift at 6500.
Mind you I have a built up bottom end and I'm using a fluidamper.
Old Feb 26, 2003 | 10:36 AM
slashz28's Avatar
i got my pcm programmed to 6700rpm, stock bottom. havent run the car yet
Old Feb 26, 2003 | 10:39 AM
redcamaroz28's Avatar
Mine shifts at 6k. It's stock as far as internal mods go, and I think the previous owner raised the redline(I think it's 5780 or 5870 out of the factory). It's an auto, so I really don't need it to be any higher, until I get headers and a cam, then I'll probably move it up to around 6200.
Later
Ryan
Old Feb 26, 2003 | 03:53 PM
Xscream's Avatar
My fall off is around 6,900 RPM on a ZZ409 and a built bottom end.
Old Feb 26, 2003 | 04:12 PM
ixd97z28's Avatar
stock
Old Feb 26, 2003 | 04:41 PM
WheelmanZ28's Avatar
My Rev Limit is currently set at 6400 RPM, but that is liable to change after my dyno tune and i see where my peak power.
I lot of people who have a stock bottom end can be very immature about their rev limit. Just because u rev the **** out of ur engine to 7000+ RPM, doesn't make u faster than any other particular engine. U select ur Rev Limit based on the point where u are making peak power. Extending ur rev limit and ur only doing more harm to the moving parts of ur engine, especially the timing chain and gear.
Old Feb 26, 2003 | 04:42 PM
FastGuyJR's Avatar
Even with a built bottom end, redline is dependent on valvetrain as well. With a solid roller lifter setup, you can rev about as high as you want, and for us hydraulic roller guys, AFR Hydra-rev helps. I still wouldn't rev past 6300 on a hydraulic roller setup, unless I just didn't care. I revved to 6500 once, and never again. I kicked a rocker arm right off the valve tip, and it was pressing down on the retainers instead. Ever since, I have been plagued by a light ticking noise and I think one or more of my lifters are shot.
JR
Flint78
Jun 21, 2015 01:28 PM
warmeck
May 7, 2015 02:10 PM
Nickster 7
May 1, 2015 09:04 PM
bossco
Nov 29, 2014 10:18 AM
The Captain
V6 Tech
Mar 28, 2003 10:32 AM
