hey shoebox!
Old Feb 25, 2003 | 11:10 PM
qwick_trip's Avatar
hey shoebox!
ok, i need help. i removed the airpump the other day and on the bottom of the air pump was a wire conector that i unplugged. that wire led to a small plastic cylinder. out of that cyliner was a hose(about the diameter of a pencil) that lead to the drivers side intake. i took that line off and pluged the plastic piece it went to. is that ok to do that? what is that line? . the line wraps around the intake to the other side. it looks like it goes to the fuel pressure regulator. if you are not sure what i am talking about i can take pics tomorrow and e-mail them to you. thanks
Old Feb 26, 2003 | 12:27 AM
Was it this thing? If you plugged the source of the vacuum, you should be ok. That was an added part when the AIR pump recall was done.
Old Feb 26, 2003 | 07:29 AM
qwick_trip's Avatar
yup that the parts i was talking about. i unplugged it and put a cap on the plastic piece on the intake. so that's ok right?
Old Feb 26, 2003 | 09:25 AM
Yep.
ecthemc
Jun 19, 2015 06:54 AM
Alex Trujillo
May 26, 2015 11:17 AM
Nellsw88
May 26, 2015 05:55 AM
chevyalltheway
May 24, 2015 04:26 PM
zxtce
Mar 12, 2015 08:06 PM
