Small Block Crate Engine
Old Feb 25, 2003 | 07:46 PM
tainted's Avatar
Guys:
Is it possible to fit a 85(hot cam) Small Block engine in there?
What about a 502 HO Big Block
Old Feb 25, 2003 | 08:24 PM
PhantomTA's Avatar
Moderator
Re: Small Block Crate Engine
Originally posted by tainted
Guys:
i dont get it
Old Feb 25, 2003 | 09:49 PM
jd13's Avatar
Where are you trying to put it? In a 4th gen?
If so, then yes, both could be made to fit with enough fabrication. I really don't think it'd be worth it though.
Old Feb 26, 2003 | 12:28 AM
tainted's Avatar
well, I was looking in a hot rod magazine when iI stumbled upon these engine blocks for sale. They said 430/450 horses for 5k i'm like...i'd get it. What I wanted to know was whether or not there would be more money involved in doing other things. I didn't know if there was or not cause I was assuming at 5k, it would be the whole engine?
And whats a 4th gen or 3rd gen or w/e?
Old Feb 26, 2003 | 01:35 AM
stik6shift98's Avatar
4th gen and 3rd gen....generation
3rd is 82-92
4th 93-02
body style generation
and i think he wants to pu it in his 2000 fbod
yes it will fit
Old Feb 26, 2003 | 01:38 AM
tainted's Avatar
Old Feb 26, 2003 | 01:48 AM
did it say just a block or whole engine????
Old Feb 26, 2003 | 03:01 AM
2002Z28SSConv's Avatar
For that $$$ get a stroker kit for the LS1 you already have. No fabrication involved and everything looks stock, except the timeslips.
Old Feb 26, 2003 | 12:51 PM
tainted's Avatar
stroker kit? how much do those run for? and for that money would I get the same performance out of the stroker kit that I would the engine?
stikshift: It's the whole engine.
Old Feb 26, 2003 | 02:42 PM
MRZ28HO's Avatar
Thumbs down
Don't do it, those older engines are not as good as the LS1s (in regards to a starting point for performance). Plus it would be a headache to make it work right. If you want to spend $5000, get a blower or a heads and cam kit (stage II) installed. Those two will put you at 400 rwhp (or ~450-470 at the crank). More than those packages in "Hot Rod", which would put down to the rear wheels like ~370-~390 plus the extra crap to make it work.
Old Feb 26, 2003 | 04:21 PM
Capn Pete's Avatar
Exclamation
I agree with the others. Do a heads & cam swap for a lot less than $5000, and without the headache. For the same amount of money or less, you could have just as much, or more power from your LS1.
The only "swap" I'd consider (along the lines of what you're suggesting) would be the 502 big-block, but even still, I think it would be a huge pain in the asphalt to convert everything, but at least the outcome would be worth it. However, I think I'd still stick with the factory base (ie: LS1/LS6 small block) and put $5000 into it if that's what you want to spend. IMO, you'd get way more for your money.
Old Feb 26, 2003 | 05:18 PM
Check the GP section. There's usually one going on, just finished or trying to get started.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
nballisru
Dec 14, 2014 05:01 PM
Perry93TransAm
Aug 20, 2002 11:23 PM
