Air Fuel Ratio's on Nitrous,(help)
Old Feb 25, 2003 | 08:51 AM
FRDnemesis's Avatar
I dynoed recently on the nitrous just to see what kind of power I could make on a stock bottom half motor with just heads and cam.
Then guy who was running the dyno stuck the sniffer in the pipe while I sprayed it. The ratio got as low as 12.8:1 and stayed steady as a rock there. The guy at the dyno said that was great. Is that true? Is that as safe as it should be on a 150 shot?
Thanks,
Jeff
Old Feb 25, 2003 | 09:45 AM
bad79z28's Avatar
FRDnem,
I have heard of ratios as rich as 9.xx:1 with 400+ hp shots. I'd think that with only a 150 shot, you should be OK, but it wouldn't be a bad idea to richen it a little. Just be careful on your total timing. If you step it up to a bigger shot, I'd recommend going a bit richer. It's always better to start on the rich side.
Just my humble opinion.
Kevin
Old Feb 25, 2003 | 10:14 AM
rskrause's Avatar
Moderator
I tuned mine for 11.5:1 on the juice+boost. 12.5:1 on boost alone.
Rich Krause
Old Feb 25, 2003 | 10:22 AM
FRDnemesis's Avatar
If I fatten up the fuel jet (NX kit) will I run a bigger risk of a nitrous backfire?
From what I have heard NX runs their kits on the fat side as it is. The car made 406RWHP 395RWTQ (Standard)
On a 150 shot it only picked up to 522RWHP 550RWTQ.
Thats only a 116 HP & 127 TQ. on a 150hp shot. I have heard NX rates their kits at the rear wheels.
Old Feb 25, 2003 | 10:38 AM
rskrause's Avatar
Moderator
They rate them the same as anyone else, by the size of the N2O jets. How much hp a given combo will see has a lot of variables. In my case, a 150hp hp shot got 125rwhp with some timing taken out. So I wouldn't say you are too far off. What was the bottle pressure when you made your run? Nitrous delivery is a function of bottle pressure, as well as jet size.
Rich Krause
Old Feb 25, 2003 | 10:50 AM
FRDnemesis's Avatar
Rich Krause
Rich,
I had the bottle pressure at about 1,000 - 1,050 psi.
Old Feb 25, 2003 | 11:08 AM
rskrause's Avatar
Moderator
Rich,
You would have made a bit more power with another 100psi or so.
Rich Krause
Old Feb 25, 2003 | 11:10 AM
FRDnemesis's Avatar
With a full 10pound bottle and a 150 shot of 1,100psi how many 1/4 mile passes should I be able to get?????
Old Feb 25, 2003 | 11:13 AM
rskrause's Avatar
Moderator
General rule of thumb: 100hp = 0.8lbs/10 sec. I can get 4-5 passes out of a 10lb bottle with a 150hp shot.
Rich Krause
Old Feb 25, 2003 | 11:15 AM
FRDnemesis's Avatar
Which brand bottle heater are you using?
Old Feb 25, 2003 | 09:13 PM
rskrause's Avatar
Moderator
NX. Seems to work fine.
Rich Krause
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
97ss1826
Mar 13, 2003 11:58 AM
Burn_Out
Aug 18, 2002 08:49 AM
