BMR bolt-in relocation brackets.
Old Feb 25, 2003 | 01:02 AM
DjArcadian's Avatar
Is there any type of drilling or modificatiion required to install these or are they straight bolt ins?
Old Feb 25, 2003 | 01:38 AM
My Mighty White 95 Z28's Avatar
it is pretty much straight bolt-on.
Old Feb 25, 2003 | 04:32 AM
SStupid's Avatar
Waste
Don't waste your money on the bolt-in model. They recommend welding the bolt-in model, anyway. Why pay more for a powder coating that's going to get ruined in the process. I ordered the weld-in. They bolt in as well, and then you weld around the edges. They honestly don't look any different except for the powder coat. Spohn has the best deal on weld-in style. GMHTP installed some bolt-in BMR units on the Grape of Wrath in the issue previous to the latest. They recommended welding them, as well. Crazy, I say. It's nice to own a welder and be able to do your own welding.
Old Feb 25, 2003 | 12:00 PM
DjArcadian's Avatar
Do the weld-in ones requires any type of drilling or modification to the rearend?
Old Feb 25, 2003 | 12:33 PM
As far as the BMR bolt-in bracket goes, BMR told me that you could also weld them, but would only really need to if your car was in the 10's or you were pulling 1.5 60' times. If you want to be able to remove them some day, just get the bolt-in ones. Sure, the weld in ones are the most secure option, but you have a choice if you want it and don't need to weld unless you have the specific need.
I find their bolt-in design extremely secure and they have not budged since I put them on 1-1/2 years ago.
Old Feb 25, 2003 | 01:06 PM
All_Z_Way's Avatar
I have the bolt in and I open track my car at the road course and have never had a problem.
I check the bolts before each event, but I have never even had to tighten them.
Old Feb 25, 2003 | 01:20 PM
No. They slide over the stock LCA brackets and the edges get welded together.
SPOHN WELD-INS
Old Feb 25, 2003 | 01:23 PM
97WRAITH's Avatar
Will the help with traction? or are they just for lowered cars.
Old Feb 25, 2003 | 01:25 PM
If you are making decent power, they will help a lot on a stock height car.
football4life
Oct 4, 2015 07:48 AM
JJOHNROE
Sep 8, 2015 05:39 PM
97blackformula
Aug 27, 2015 06:02 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
realistyc
Jul 28, 2015 07:32 PM
