Stroker Kits
Old Feb 24, 2003 | 01:53 PM
Smitty71's Avatar
Stroker Kits
Who has the best deals on 383 rotating assemblies??
I'm in high school so money in my pocket is like ummm hardly every there?? I was thinking of a kit around $1000 or less.
Smitty
Old Feb 24, 2003 | 01:59 PM
IDOXLR8's Avatar
To be honest you are not going to be able to find a decent kit for that price range. You may want to call up Summit. Remember there is cost involved in machining the block and balancing the rotating assembly unless you buy a kit is balanced.
Old Feb 24, 2003 | 02:47 PM
Will84's Avatar
Check here
http://www.strokerkits.com/383_lt1_stroker_kits.htm
Old Feb 24, 2003 | 03:36 PM
Gripenfelter's Avatar
You get what you pay for and for $1000 you're gonna get junk if you're looking for a complete kit.
You might wanna consider doing some other mods rather than a stroker.
Strokers always have hidden costs.
Old Feb 24, 2003 | 03:41 PM
Will84's Avatar
SCAT cast steel 3.750" stroke crankshaft
6.0" SCAT I-Beam 4340 moly rods w/bushed small ends
ARP bolts
Probe forged pistons
Clevite-77 or Fed-Mogul bearings
Sealed-Power moly rings
Steel Crank Upgrade available
$1250
Sounds pretty good to me
Old Feb 25, 2003 | 05:42 AM
badass383's Avatar
Jeg's has 2 kits from Eagle. Already balanced with Dampener and Flexplate one was less than $1K the other was like $1100.00.
If your gona blow or spray, you need to 4 bolt it. That means align bore. $200 to $500.00 for that step alone.
My only suggestion is do it right so you only do it once.
RUENUF
Mar 13, 2016 03:39 PM
D1SC383LT4
Jan 1, 2016 01:56 PM
Drtryder
Apr 22, 2015 04:17 PM
Sauced
Apr 12, 2015 10:18 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
