Underdrive Pulleys.. Are They Worth It???
Old Feb 24, 2003 | 12:32 AM
nB5sP's Avatar
my friend threw on a under drive pulley and said he could feel a little difference. but i also read someware that there are dampers in the stock pulley that help get rid of some vibration.. i think it was on hondas but is it true for all cars?
anyone know if there's any other negative things about them? i don't have a sound system that requires extra power so i'm not worried about that issue.
thanks!
Old Feb 24, 2003 | 09:41 AM
syacoub's Avatar
I put in an underdrive pulley on my car with the overdrive alternator pully and I love it! Definitely can feel the difference. Just don't let the car run for a while on idle then shut it off. The car needs to be in higher rpm's for the alternator to charge up the battery.
Definitely worth it!
Old Feb 24, 2003 | 10:07 AM
teke184's Avatar
the stock balencer is an integral part of the stock pulley. therefor most of the underdrive pullies available are designed to have the stock pulley/balancer piggy-back the new pulley. if you dont' you will cause problems.
typically it falls into the "every little bit helps" category. i don't think it was noticable when i installed mine...
according to ws6.com he got 0.7hp and 5.1# of torque, don't think that would be noticable, but i'll take it.
Old Feb 24, 2003 | 10:51 AM
GREGG 97Z's Avatar
Re: Underdrive Pulleys.. Are They Worth It???
thanks!
As mentioned, I hope your freind reinstalled the stock pulley/harmonic balacer on top of the underdrive pulled. I have heard of some people just running the underdrive pulley and leaving the balancer off, that is a very bad idea, it could cause major damage to the crank.
Old Feb 24, 2003 | 11:17 AM
95_RipperZ's Avatar
I like mine. At first it threw some codes but after resetting the PCM it ran fine. I think I gained 1 mph from it too. Not too sure thoug b/c it could have been the TB bypass with it and also the weather.
Old Feb 24, 2003 | 11:25 AM
PatriotTA's Avatar
I am using the piggy-back style pulley too, and I like it. It's a BBK. I'm not using an alternator pulley, though. After I installed it, I seemed to notice a little more throttle response. It may be a problem for people that run big stereo systems, but the loss of charging efficiency never bothered me (I don't have any extra speakers or anything).
blaze309
Sep 8, 2015 05:27 PM
colts0455
Sep 2, 2015 12:41 PM
mark0006
Aug 29, 2015 09:45 AM
Slayer
Aug 17, 2015 03:55 PM
whitehooptie
Aug 17, 2015 08:35 AM
