traction problems
Old Feb 23, 2003 | 09:59 PM
Bone Breakin's Avatar
Question traction problems
OK guys i lowered my car with the eibach sportline kit. I got BMR LCA's and relocation brackets hoping to fix my the traction problem that lowering would cause. Its not enough. I used to be able to start off light with first gear, then nail second, now if i do that i burn em when i get to second. So how can i get better traction?
Old Feb 23, 2003 | 10:02 PM
qwick_trip's Avatar
are you running slicks?
Old Feb 23, 2003 | 10:25 PM
no this is mostly a street driven car. but i do race from time to time, need decent traction.
Old Feb 23, 2003 | 11:29 PM
Got-LT1's Avatar
try some drag radials maybe?
Old Feb 24, 2003 | 12:06 PM
i was thinking of tryin that, if i got them larger than my fronts would that help as well?
Old Feb 24, 2003 | 12:25 PM
TedH's Avatar
Drag Raidals are the first thing to get, or ET Streets if you start to get serious about it. Try running about 18-20 pounds at the track and adjust from there.
Lowered cars have a more difficult time hooking up at the track becasue weight does not tranfer as easily. You can also try disconnecting one end of your front sway bar and see if that helps too.
Beyond that you are generally into suspension mods that will impact your cornering ability.
Rod Bender
Nov 7, 2023 02:30 PM
dluna333
Parts Wanted
Mar 6, 2015 07:11 AM
squarehead
Jan 15, 2015 07:02 PM
Teal94V-6
Aug 31, 2002 09:21 PM
jp2002ls1
Jul 22, 2002 04:18 PM
