longtube or shortys? for 1/4 time
Old Feb 23, 2003 | 06:37 PM
glennxx1's Avatar
which do i want?
Old Feb 23, 2003 | 06:42 PM
RamAir95TA's Avatar
Long tubes will provide substantial horsepower over a shorty-style header, due to the improved exhaust scavaging characteristics because of the longer primaries. Shorties are emissions legal, and have EGR and AIR fittings.
Most long tubes will fail emissions, and all long tubes will fail visual inspection, because of the relocation and/or deletion of catalytic converters, which is illegal in most states.
Mid-length headers are a good alternative to either. MACs and AS&Ms provide almost the gains of long tubes, but still remain emissions legal.
For strip use only though, I'd definitely go with long tubes. Keep in mind, you will need to have a custom y-pipe created, as long tubes will not bolt up to the factory exhaust.
Old Feb 23, 2003 | 06:59 PM
glennxx1's Avatar
what if im gettin cat back exhaust? i dont have to pass emissions, so go with longtube?
Old Feb 23, 2003 | 07:13 PM
JustaLT1's Avatar
Definately get long tubes over shorties. You'll pick up a lot more horsepower with the long tubes. Like RamAir said...the long tubes have better exhaust scavenging. Meaning you will get 10-15 more horsepower to the ground with a long tube on a bolt-on car. The benefits will be even greater than that with a cam and/or heads.
Old Feb 23, 2003 | 07:17 PM
glennxx1's Avatar
i was also wonderin if i got a cam and foudn out what #'s i needed on my heads how hard is it to see what ur makin the intake/exhaust on the heads be? could i port n polish them or def. take to some 1?
Old Feb 23, 2003 | 08:38 PM
lbrowne's Avatar
Do you need a custom Y-Pipe to run the MAC headers? On either a dual cat 96+ or a single cat 95?
I think theres a header that bolts right to the stock Y-Pipe, I think it was SLP....
Old Feb 23, 2003 | 08:39 PM
glennxx1's Avatar
bump
Old Feb 23, 2003 | 08:58 PM
ltlhomer's Avatar
MACS come w/ a ypipe, and that's definitly the way to go if you don't go w/ longtubes.
Old Feb 23, 2003 | 09:10 PM
lbrowne's Avatar
so it bolts up to the stock I-Pipe then?
Old Feb 23, 2003 | 10:26 PM
qwick_trip's Avatar
the macs have the y pipe with them. they are a great set i got them everything bolted up great.
Old Feb 23, 2003 | 10:47 PM
lbrowne's Avatar
MACs for my car would be different though since I have a dual cat setup. In fact I think they're more expensive for a dual cat car....
Old Feb 23, 2003 | 11:21 PM
Highlander's Avatar
I thought that with a stock car and cam the shorties gave it a better punch, since you get the torque down low the LTs dont give you and since you are not pumping that much air out, the total gains are the same, so shorties where the way to go with a stock car. If you later modify I know its long tubes.. but for stock
Old Feb 24, 2003 | 01:51 AM
lbrowne's Avatar
thats what i understood...
Old Feb 24, 2003 | 02:11 AM
chesee48's Avatar
Enough said...
GET THE LT'S!!
Old Feb 24, 2003 | 01:40 PM
glennxx1's Avatar
how much does it cost to get ur heads ported/pollished /matched to a cam?
