quick question
Old Feb 23, 2003 | 12:54 PM
9730thz28camaro's Avatar
Question quick question
I was woundering why some people put the lt4 knock module into their lt1 computer??
Old Feb 23, 2003 | 01:07 PM
drop top steve's Avatar
To reduce false knock caused by roller rockers. False knock should not be an issue on a stock LT1 engine. Mods like roller rockers, headers can cause false knock that can kill performance. You need some datalogging software to see if you have a knock issue, then you need to determine if it is false knock or not. That's usally done but running a higher octane fuel to see if the knock is reduced.
Old Feb 23, 2003 | 01:08 PM
qwick_trip's Avatar
because the lt1 knock module is so sensitive if you have roller rockers(because roller rockers are noiser) it will read false knock and retard the timing and you will lose horsepower. the lt4 knock module is made for a roller rocker engine.
Old Feb 23, 2003 | 03:05 PM
96cam4ro's Avatar
You need someone's scanmaster ($230) to figure out if you've got false knock or not.
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
Jan 23, 2015 01:13 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
