tranny help
Old Feb 23, 2003 | 01:17 AM
windnsea00's Avatar
Question tranny help
today i was driving around my neighborhood when my tranny acted up like crazy. when it would shift under decent throttle the whole car felt like it got hit by another car. it was so harsh. but it felt like it was shifting ok...sure scared me though...any clues what this could of been?
Old Feb 23, 2003 | 01:29 AM
hvyss's Avatar
It sounds like for some reason the PCM is boosting the line pressure. Do you have a shift kit? If you have a laptop or know someone who does with a OBDI cable and Freescan hook it up and see if it shows any codes. The most common is 1870( converter lockup problem.) Do you have a stall and does the car lockup? Like I said it sounds like the PCM is boosting line pressure for some reason. Good luck.
HVY SS
Old Feb 23, 2003 | 01:50 AM
windnsea00's Avatar
No my car is all stock...i got like 2-3 weeks ago and being a teenager im already low on money and saving up for a whole new rack and pinon, tie rods, fix an oil leak and new rotors and pads all around. and all i need now is tranny problems!!
Old Feb 23, 2003 | 02:03 AM
hvyss's Avatar
If it is stock they I would have to say yes you have a tranny problem. You need to get it checked before if fries the tranny. I twisted a Tranny output shaft for the same reason. My tranny shifted so hard that the whole car vibrated and jerked my neck. Hense busted trans. A stock rebuild will cost you over 1000 dollars if you dont break anything before hand. So get if checked out before it breaks and costs you alot of money.
HVY SS
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
