5176 Dry shot track results
Old Feb 22, 2003 | 03:02 PM
mtxpert's Avatar
Just got back from the track!
First - here's the weather!
65°F
Dew Point: 36°F
Humidity: 34%
Pressure: 29.89 inches and falling
Wind: From the South at 6 mph
Here's the results!
Well, I started with a first pass of 3200 rpm bottom 5200 rpm top of window
1.876 60'
5.29 330'
8.161@85 1/8
12.78@108.88 1/4
I decided to adjust my window to 3100 - 5300
1.866 60'
5.362 330'
8.277@83.932 1/8
12.979@104.717 1/4
Lot's of knock retard at top of shift - nitrous is too high I figured but 60' is improving SO
I changed it to 3000 - 5200 rpm window
1.780 60'!!!!
5.15 330'
8.017@85.971 1/8
12.58@110.409!!!!
Woo hoo baby!
Mike
Old Feb 22, 2003 | 03:21 PM
COMNBYU's Avatar
what kind of shot were you running? nice times!
im hoping for 11s this season. first weekend of 03 season is next week!!! its put up or shut up time. she's either gonna haul *** or break
you car mostly stock?? whats it run NA??
jon
Old Feb 22, 2003 | 03:30 PM
mtxpert's Avatar
I ran a 14.45 right after that run, idling in the lanes for about 10 minutes. Probably would have ran a low 14.3 or high 14.2 if I could have let her cool down again.
175HP shot....
http://www.azsupersport.com/pics/timeslips2-22.jpg
Not too shabby for a stock motored 4400 lb Impala SS
Old Feb 22, 2003 | 04:00 PM
COMNBYU's Avatar
ahhhh.....
i feel stupid now. i didnt know you were takling about an Impy.
in that case, VERY nice times
thats alot of juice. ill be running a 150 this season.
hopefully more than one time....
you running a stock bottom end?
jon
Old Feb 22, 2003 | 05:01 PM
mtxpert's Avatar
Here's my mod list:
NOS 58MM TB
GMPP 1.6 RR’s – stock valve springs - stock cam
Holley Afterburner headers – no cats
Dynomax 2.5” catback exhaust
Meziere Electric Water Pump
PCMforless programming – with personal modifications
30lb SVO injectors
Walbro 340 in tank fuel pump
NOS inline fuel pump
TR6 plugs - .035 gap
Taylor over the valve cover plug wires
Mallory 685 Ignition – includes window switch, timing retard and 2 stage rev limiter
Rebuilt stock converter – 2500 rpm stall
3.08 Stock Gears and posi
4” aluminum driveshaft
NOS 5176 nitrous kit – 175HP shot (90 PSI at the injectors)
ATPSS – electronic full throttle switch
NOS Fuel Pressure Safety Switch – 65 PSI
Stage – Hold brake (2nd rev limiter comes on at 2100 rpm) and floor it! Nitrous engages at 3000rpm to 5200 rpm (shifts set to 5200 rpm for all gears).
Release brake and go.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
TitoPR221
May 26, 2015 12:20 AM
PublicEnemy1
Apr 7, 2015 12:21 PM
