Removing vapor canister and rerouting lines
Old Feb 20, 2003 | 09:31 PM
Stealth Z's Avatar
http://nkyfba.homeip.net/attachment.php?s=&postid=3607
Anyone have any instructions how to remove this and how to reroute the lines?
Old Feb 20, 2003 | 09:43 PM
Buttercup's Avatar
Why are you removing the EVAP? Usually the only cars without this are the much older cars with vented gas tanks.
Old Feb 20, 2003 | 10:02 PM
Crucial 97 TA's Avatar
in order to mount vette fuel rail covers does that need to b removed ?? ... i was mocking my FRc up and it seems to b in the way .... what have u guys that have the rail covers done ?
Old Feb 21, 2003 | 03:50 PM
TTT
Old Feb 21, 2003 | 04:26 PM
I can see no reason why you would want to remove it. All the obsession about removing things on the LT1 kinda baffles me. Most of this stuff has to do with emissions. I am not exactly a tree hugger, but if the stuff is there to help protect the environment and removing it does nothing to affect horsepower, why would you not maintain it in working order? If you have lived long enough, you will already know how much we have screwed up the environment.
Old Feb 22, 2003 | 12:10 AM
Old Feb 22, 2003 | 12:38 AM
Can we assume that if you are only worried about mounting Corvette fuel rail covers, your problem is not the EEC canister, but is the EEC purge solenoid, that sits on the bracket on the passenger side of the intake? If that's a problem - and I have no idea if it is, because I'm not a fan of covering up the injectors and rails and retaining heat - just move the solenoid. Don't remove the entire EEC canister system.
I'm with Rob/Shoebox. AIR, EGR and EEC do NOT hurt performance in any way. The EEC system keeps a lot of fuel stink out of your car. I'm running an 800HP stroker, and as long as it was street driven, I went out of my way to keep all those systems operating.
Old Feb 23, 2003 | 09:10 PM
anyone with fuel rail covers wanna tell me what they did with there stuff?
Old Feb 23, 2003 | 10:56 PM
L44's Avatar
L44
we cut out a little bit on the covers and sanded them nicely =), there was a post on the polished ones i bought sometime back or you can checkout http://home.ptd.net/~badbird/savage_customs.htm and have custom ones built up but they will definately cost you some $.
Old Feb 28, 2003 | 04:08 PM
link doesn't work ...... TTT
Old Feb 28, 2003 | 04:44 PM
mtxpert's Avatar
http://www.impalaperformance.com/fuelrailcovers.html
Here's the trick, remove the items from the bracket and just shove them down in the valley between the intake and the valve covers...
Mike
Old Feb 28, 2003 | 08:26 PM
thanks .... glad to get a anwser .....thanks a ton ....
Victor Lamb
Aug 26, 2017 02:52 PM
blac94Z
Nov 28, 2014 01:53 PM
squarehead
Nov 21, 2014 08:02 PM
