Changing Shift Points for a 95 Camaro
Old Feb 20, 2003 | 08:54 AM
reyals's Avatar
How do I go about changing shift points?
I'm using FAST and the only thing my stock computer is used for is to control the dash and 4L60E tranny.
If I make an interface cable is there a program that will let me change these shifting points?
Old Feb 20, 2003 | 10:39 AM
c5formetoo's Avatar
any of the lt1 edit,tunercat,or even a hpp will let you adjust the trans.
Old Feb 20, 2003 | 10:44 AM
ablackcamaro's Avatar
How strong are the auto trannies? I have a 95 Formula with the o/d tranny... I believe it's the 4l60e or something? I have tunercat but didn't know how much to raise the shift points or if it's even worth it... can the tranny hold up? The car has 110K miles on it but had a rebuilt tranny put in at around 90K I believe...
Old Feb 20, 2003 | 10:48 AM
c5formetoo's Avatar
imo in a stock car there is no benifit to raising the shift points.it will just make it rev higher than it makes power,and hurt performance.
Old Feb 20, 2003 | 01:51 PM
c5...that's exactly what I was thinking. What do you think about raising the shift firmness though? Wouldn't that be the same as making it shift quicker? I recorded a WOT run through a gear to get a shift recorded in DataMaster and the shift looked like it took some time to get through... although I'm not sure how long they're supposed to take... but could that in effect make the car quicker in the quarter if it shifts not higher but quicker?
Old Feb 20, 2003 | 05:40 PM
c5formetoo's Avatar
you can increase the firmness,and it should help.some people dont like making them shift harder claming a durability problem but i have mine pretty firm with no problems so far.
Old Feb 20, 2003 | 08:35 PM
One of the things I like most about my car... which I also plan on taking advantage of, is the "performance" button for the tranny. So I can adjust the tables for shift firmess when in performance mode, and have normal shifts when the button isn't on. I'll keep the actual shift points the same though.
Old Feb 20, 2003 | 08:59 PM
c5formetoo's Avatar
that will work good
Old Feb 20, 2003 | 10:33 PM
scott95ta's Avatar
C5, are you going to increase the line pressure to increase "firmness"? If so how much?
I am new to all this programming stuff, so sorry if this questions seems a little silly.
I am doing alot of reading before I make any changes, that way I hopefully know a little about what I am doing.
Old Feb 20, 2003 | 11:00 PM
c5formetoo's Avatar
increasing the line pressure is the way to do it.there is a table called line pressure offset in current gear.in that i added to the numbers there.i will e-mail you a tunercat file if you are using tunercat
Old Feb 21, 2003 | 10:39 AM
Hey C5... it'd be much appreciated if you could send me the file too! It's tomnjery@optonline.net ... thanks a lot. Did you add to every cell in the table or just a few?
Old Feb 21, 2003 | 11:51 AM
c5formetoo's Avatar
all the tables have been adjusted.i sent you mail
Old Feb 21, 2003 | 11:03 PM
Thanks for the email sorry I would have just replied to the email itself but I deleted it before I got a chance to respond to it... silly me!
PCLZ28
Dec 24, 2015 05:19 PM
cmdeshon
Dec 27, 2014 10:06 AM
NewsBot
Dec 3, 2014 12:30 PM
Sarahrope64
Nov 27, 2014 11:17 AM
Jul 4, 2005 05:00 PM
