miss or cutting out and icm?
Old Feb 19, 2003 | 06:59 PM
billy-94z28's Avatar
Hey guys, it is me again and i am still fighting that miss in my 94 z28 6 spd. I put a new coil and coil wire on this afternoon and it seemed to help a little. What does the icm do exactly? The miss does not develop until the car is up to operating temperature.
I checked my water pump and the weep hole was dry right after i drove the car. It only misses or makes a noise like a carburetor engine coughing back through the carb. (but not everytime). It feels like it is missing and i hear detonation sound like a 70's car running on unleaded. Original plug wires and I checked the driver side wires at the optispark and they "looked" good but I know that does not mean a lot.
Please reply with any input or help,
Thanks a lot everybody.
Old Feb 19, 2003 | 10:06 PM
The ICM receives pulses from the pcm and then signals the coil to fire. It can be affected by heat if there is a crack in it or maybe a marginal circuit tracing or component inside it. The optical sensor in the opti can be susceptible to the same thing, though you should get a trouble code in that case. There are some auto supply stores that supposedly can test the coil module.
TSAEB
Mar 17, 2024 09:08 AM
markzzzz
May 8, 2015 09:21 AM
Lt4Z2897
Mar 26, 2015 03:02 PM
armedtrigger
Feb 24, 2015 08:30 PM
cmdeshon
Dec 12, 2014 10:51 PM
