Could misadjusment of rockers cause pinging?
Old Feb 19, 2003 | 11:02 AM
max929's Avatar
I had some work done the car.
Car ran fine except it was blowing smoke.
The exhaust seal where changed and no more smoke, but now it pings at about 1700 to 2000 rpm under load.
Old Feb 19, 2003 | 11:07 AM
IDOXLR8's Avatar
If your rockers were not adjusted right then you would hear a tapping noise as oppose to a ping. How did you adjust your rockers?? Are they set loose?? How far past zero lash did you go?
Old Feb 19, 2003 | 11:10 AM
max929's Avatar
It's not tapping it's pinging.
I believe he went less then half turn.
Old Feb 19, 2003 | 11:19 AM
94SLUG's Avatar
We went over this on the last post about pinging. Did you go and get your car scaned. We need some o2 reading and knock reading. What plugs are you runing?
Old Feb 19, 2003 | 11:29 AM
IDOXLR8's Avatar
As stated earlier have you scanned your car?? Pinging is usually in reference to detonation. I know with 93's some people desensitize there knock modules to prevent timing being pulled due to false knock.
Old Feb 19, 2003 | 12:34 PM
drop top steve's Avatar
If you where burning oil in the past you could have a carbon build up in the compustion cambers and on top of the pistons. Run some top end cleaner (seafoam) through the engine and see if that helps.
Old Feb 20, 2003 | 08:05 AM
max929's Avatar
I will do that today.
[i]We went over this on the last post about pinging. Did you go and get your car scaned. We need some o2 reading and knock reading. What plugs are you runing?[/B]
Yes she was scanned and nothing out of the ordinary.
She takes a while to go to closed loop, but I associate that
with headers and non heated o2 sensors. The plugs NGK TR55, I think I will pull one off to see if they got caked up from the intial smoking problem.
Thanks for your help guys.
I will keep you posted.
Old Feb 26, 2003 | 08:24 AM
max929's Avatar
http://web.camaross.com/forums/newre...threadid=85732
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
