Whos got a Harlan Window switch
Old Feb 19, 2003 | 01:37 AM
Blue89Bird's Avatar
so.... its got 5 wires on it... how do you hook it up.
One is ground, easy
One is switched 12 v, also easy
other is tach output.... where do I get that from, ecm?
Other is the output, I assume the power wire goes from the solenoids to this? how do i hook this part up?
the other is a switched ground? what is that
is says something in the directions about not directly hooking up the power wire and to use a relay? what kind of relay? how do you wire that? I hate wiring things!
Old Feb 26, 2003 | 08:06 PM
craigffb's Avatar
I went to the order page and there isn't even a picture of the thing. Is it pretty nice? Or would you just get one from MSD or Mallory if you had to do it again?
Old Feb 26, 2003 | 08:19 PM
Blue89Bird's Avatar
i didnt order it yet.
From what Ive heard its just as good as the others, but cheaper.
It also doesnt use pills, its completely adjustable, so thats good as well.
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
z28cam1993
Sep 9, 2015 04:08 AM
