if my ac leaked out........
Old Feb 18, 2003 | 09:13 AM
slashz28's Avatar
hi guys i busted one of my ac lines reinsatlling my radiator last night and all the ac leaked out. i could start my car up and have no probs as long as i dont turn on the ac i suppose?? or does it have to be recharged before i start my car? thanks
Old Feb 18, 2003 | 09:15 AM
DR.ZED's Avatar
Re: if my ac leaked out........
Disconnect the electrical connector to the compressor, so it doesn't turn on and run "dry".
Get it charged back up after you fix it, I can't imagine that the closed system would like to be exposed to the elements with it broken and letting air and moisture in.
Old Feb 18, 2003 | 09:26 AM
slashz28's Avatar
the compressor turns on even if i dont turn it on?? or youre saying to unplug it just in case someone turns it on by accident? thanks.
Old Feb 18, 2003 | 09:50 AM
DR.ZED's Avatar
It comes on in all but two settings on the climate control (only floor and only vent). All other settings it activates.
Old Feb 18, 2003 | 10:35 AM
94SLUG's Avatar
If you broke a line you already lost enouf pressure to where you cant engage the compressor. It will spin but its not working the clutch did not engage unless you still have good high/low pressure. You dont need to unhook anything. if you turn ac or the car on nothing will happen.
Old Feb 18, 2003 | 10:38 AM
DR.ZED's Avatar
Thats a great point, and you're right. Don't worry about disconnecting anything, if the pressure is significantly lost.
Old Feb 18, 2003 | 11:02 AM
slashz28's Avatar
thanks for the help guys i appreciate it
Jeff1904
Jun 5, 2016 05:00 PM
magman
Apr 15, 2016 03:08 AM
blac94Z
Nov 4, 2015 01:59 PM
drt
Sep 27, 2015 04:39 PM
colts0455
Sep 27, 2015 01:07 PM
