Sub Box + Rear End Weight
Old Feb 17, 2003 | 11:21 PM
KevinAce's Avatar
I know the extra 60-80 lbs I have in my trunk is a negative because of weight. But how much do you guys think it helps with traction? I'm trying to see if I want to keep them cause I like the sound, or get rid of them for better performance. I'd imagine that 60-80 lbs right over the rear axle probably helps a bit with traction, as well as moves the center of gravity towards the rear.
Old Feb 18, 2003 | 08:18 AM
camaros_4_lfe's Avatar
it does help with traction quite a bit and it dont slow you down much at all
i had 3 15 lb twelves and a 36 pound amp plus like a 40 pound box in my car and only ran 15/100'ths of a sec faster at the 1/8th mile without em cause of less traction
Old Feb 18, 2003 | 09:32 AM
ibanez6rg's Avatar
I remember when I had mine in the back I used to be able to only spin through 2 gears (in rain) and then I took them out and tried it and went through 4 gears spinning (in rain).
Mine probably weighs around what yours does
Old Feb 18, 2003 | 01:54 PM
Bliggida's Avatar
They will help with traction. But it will slow you down ever so slightly too.
For every 100 pounds of weight you add you will go a 10th of a second slower in the quartermile.
so 50 to 100 pounds if fairly harmless.
That means if you use to run a 14.4
Now with an awesome stereo to boot, you'll run a 14.5
Old Feb 18, 2003 | 03:15 PM
KevinAce's Avatar
Yeah, I think I'm going to end up keeping the equipment in. Right now punching it off the line (K&N and other induction ****, FTRA / Whispier lid) really gives me some good throttled reponse, so they'll still spin like crazy...probably less than if I didn't have the stereo though.
Old Feb 18, 2003 | 09:02 PM
2kredcamaro's Avatar
Hey I just purchased the exact same system for my car. How does it sound?
Old Feb 18, 2003 | 11:33 PM
KevinAce's Avatar
It sounds fantastic! I've heard $1000+ systems in other peoples' cars and this matches them just fine (especially with this Monsoon system). It's American Legacy 2 rated at 1600 watts, and Pyramid Hyper Pro's rated at 1000 watts. These are way over rated. Realistically, we're talking 1000 RMS for the amp, and 500 RMS a piece for the subs - which is a ton!
I give them 100% approval, especially for the price!
Old Feb 19, 2003 | 09:32 AM
Pyramid
Old Feb 19, 2003 | 04:52 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
ok, no im not trying to start a flaming war here... but how do all you guys have all this much trouble with traction?? dont get me wrong if i want to blaze my tire i can... but when im racing i dont have trouble at all. when you guys are racing are you just planting the gas
oldschool
Feb 9, 2016 09:21 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
