removing air pump , egr
Old Feb 16, 2003 | 10:38 PM
JJJ93z's Avatar
i had someone tell me that removing your air pump and egr frees up exhaust for more hp. what is an air pump and egr? what do they do? will my ecm throw codes upon removal,? can my engine be damage upon removal? i am in an area where emmission control is not a prob. thanks for your imput
Old Feb 16, 2003 | 11:26 PM
ChuckZ28's Avatar
you wont get any real noticable gains. I did them just because i was bored and its useless stuff. I didnt get any codes after removal of the air pump and I just used a block off plate for the egr. The egr (exhaust gas recirculation) puts exhust back into the intake. it is located in the back of the intake manifold from a little tube out of your passenger side exhaust manifold. The air pump just warms up your cat convertor when you start the car to reduce emmisions. its only on for a couple min. It is located on the front of the engine block on the drivers side and has rubber tubes coming out of it, you can follow them to see where they connect and block off the hole left over in your intake, keep the wire covered that you disconnect. Im not sure if its supposed to set any codes but the SES light didnt come on for me. Hope this helps
Old Feb 16, 2003 | 11:30 PM
1msfyter's Avatar
The EGR pipe, what did you use to cap or block it?(on the exhaust pipe) Is it a plug?
I removed my air pump and used the m22 plugs.
Old Feb 17, 2003 | 05:43 PM
ChuckZ28's Avatar
I actually used one of the metal spark plug covers, flattened it cut it and drilled it to fit right on the back of the manifold inbetween the pipe and maifold.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
cmdeshon
Dec 27, 2014 10:06 AM
CamaroZBoy
Sep 9, 2002 10:33 AM
CamaroZBoy
Sep 1, 2002 09:48 AM
