changing plug wire your self...any instructions??
Old Feb 16, 2003 | 12:11 PM
TMDZ28's Avatar
i'm looking for any instruction that will help me to change my plugs and wires by my self...i saw this done to my car a year a go, and i would like to do it right by myslef now....any suggestions??
Old Feb 16, 2003 | 12:15 PM
Greasepunk's Avatar
Do 1 wire at a time
Get some ramps or jackstands
A length of rubber hose to start the somewhat hard to reach plugs
double check your wires to make sure they won't get burnt on anything
take your time !
Old Feb 16, 2003 | 12:20 PM
TMDZ28's Avatar
thanks grease....i start to do it next week....hmmm, getting nervous here
Old Feb 16, 2003 | 12:25 PM
Loadre's Avatar
It's not nearly as hard as it is time consuming. If you can't get to something, try orientating your body several different ways until you can get it. If you still can't get it then try removing something until you can get a better angle A wide assortment of extensions etc is also very helpful. If you're doing it by yourself you might get it done in a weekend, but have a backup car just in case something goes awry.
Old Feb 16, 2003 | 12:26 PM
Mikey97Z's Avatar
Plug #7 runs through a metal shield, just below the #5. You have to remove it to get the new wire through the shield. Find the 2 screws that hold the shield to the block. You may only have to loosen them to slide the shield out from under them. Good luck!
Old Feb 16, 2003 | 12:30 PM
camaroz28_97's Avatar
having two people make it much easer . I removed the starter to get to the last two on the passenger side.
Old Feb 16, 2003 | 08:32 PM
TMDZ28's Avatar
is there any web instruction where i can see the instruction step by step...i think it's a bit confusing than i think it is
Old Feb 16, 2003 | 09:31 PM
Blk94Z28LT1's Avatar
the drivers side isn't to bad. But the passenger side damn it's tough. I had to remove the PS pump to do mine.
MRBoss429x's Avatar
Post
Im on the same boat as you TMD. I want to change my wires, and plugs for that matter, myself. I dont have TOO much experience and I also dont want to F up my ride. I guess thats why god invented the camaroz28.com message board .
PCLZ28
Dec 24, 2015 05:19 PM
grgguy
17
Feb 23, 2015 07:57 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Jazsun
Dec 29, 2014 12:14 PM
