Help....
Old Feb 16, 2003 | 11:55 AM
AcidDrag0n's Avatar
Help....
Alright, When i'm driving down the road listening to my music and all sometimes when I hit a bump or small pot hole it seems like a "lose" a lot of my bass, but then when I hit another bump or pot hole it comes back. It did the exact same thing with my old system except in it, when you hit a bump and lost the bass you couldn't hear ANY at all until the next bump came around,but with my new system you can still hear it, just not as much. Since it has done this in both systems I know it can't be the Sub,Box,or the Amp. Could it be the wiring from the battery? I need to fix this!
Old Feb 16, 2003 | 12:09 PM
LS1 RULZ's Avatar
Whenever I have encountered this problem it has always been a bad or cold solder joint on the circuit board of the amplifier. Most of the time it was where the RCA jacks were soldered to the circuit board inside the amplifier.
Old Feb 16, 2003 | 12:11 PM
AcidDrag0n's Avatar
I've had two different amplifier and have had this problem with both of them.
Old Feb 16, 2003 | 12:12 PM
LS1 RULZ's Avatar
Were they Pioneer amps by any chance? This has happened to 2 different Pioneer amps that I've worked on in the past.
Old Feb 16, 2003 | 12:30 PM
AcidDrag0n's Avatar
no, one was a Optimus and the new one is a Profile
Old Feb 16, 2003 | 12:47 PM
LS1 RULZ's Avatar
Those are both considered low-end amplifiers so it wouldn't surprise me at all if you had bad solder joints as I mentioned. Try firing up your system and jiggle the RCA plugs at the inputs of your amp and see what happens.
Do you know anyone that has any knowledge of electronics that could take a look at it for you?
Old Feb 16, 2003 | 01:15 PM
AcidDrag0n's Avatar
nope......
Old Feb 16, 2003 | 01:22 PM
LS1 RULZ's Avatar
Did you try jiggling the RCA's at the amp?
wildracer
Jul 30, 2010 12:49 PM
ttop1997
Jun 18, 2010 11:27 AM
AlwaysCode390
Oct 30, 2009 05:28 AM
sick9lt1
Aug 25, 2009 01:55 PM
1994TransAm
May 29, 2007 08:14 PM
